Old 02-21-2009, 09:18 PM   #1
70C10Step
70C10Step's Avatar
Headers?????
Truck is bagged and I will be running a 350 and 700r4. Which headers work. I heard Chevelle 3/4 length will work... Input please.... Thanks in advance...
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 02-21-2009, 09:21 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Headers?????
ECE has some nice ones, mid length, coated.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-21-2009, 09:22 PM   #3
70C10Step
70C10Step's Avatar
Re: Headers?????
I will check their site! Just placed a order on Thursday for cab/bed mounts....
All Toys:
Old 02-21-2009, 09:26 PM   #4
Skirkpat
Skirkpat's Avatar
Re: Headers?????
Your heart set on headers?
Skirkpat is offline   Reply With Quote
Old 02-21-2009, 09:44 PM   #5
vectorit
What?
vectorit's Avatar
Re: Headers?????
Been there done that with headers... Just like the previous Q, ya really got your heart set on headers? To me they have always been a royal PITA...
I have my Ram's back on after many years of headers, and I am lovin life not dealin with exhaust leaks, burnt plug wires, burnt... etc etc.
If you really want em, the last set I had on my K20 were Hooker Pro comps. They were great as far headers go on DD.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-21-2009, 09:40 PM   #6
70C10Step
70C10Step's Avatar
Re: Headers?????
Is there another option?
All Toys:
Old 02-21-2009, 10:01 PM   #7
70C10Step
70C10Step's Avatar
Re: Headers?????
Okay I see your point... Did not know about all the drama... I do have a set of rams I can run... Not a performance truck....
All Toys:
Old 02-21-2009, 10:13 PM   #8
vectorit
What?
vectorit's Avatar
Re: Headers?????
If you are not goin for every inch of performance, the rams are great and you will burn up less stuff includin your fingers.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-21-2009, 10:23 PM   #9
Skirkpat
Skirkpat's Avatar
Re: Headers?????
If you are not going for pure performance, you should be alot happier with manifolds, I like the looks of headers, but they really are alot of problems, underhood heat, loose bolts, blown gaskets, If you don't mind wrenching there O.K., But I would rather drive my truck than work on it !!
Old 02-21-2009, 10:21 PM   #10
70C10Step
70C10Step's Avatar
Re: Headers?????
Cool!!! I will go to my storage and find them!
All Toys:
Old 02-21-2009, 10:40 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
Re: Headers?????
I've had headers on 2 of these trucks and have been blessed with zero problems as far as gaskets go. I did have to wire up a remote solenoid for the starter though.
Beat it to fit,
Old 02-22-2009, 01:07 AM   #12
BigSky71
LAIDOUT
BigSky71's Avatar
Re: Headers?????
I put a set of Sanderson headers on my truck. Installed per instructions with black silicon, no gaskets, no leaks for two years, very happy.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 02-23-2009, 12:30 AM   #13
xmitsu10
xmitsu10's Avatar
Re: Headers?????
Ditto here on the Sandersons from ECE. They run much cooler than the full length Hedmans that were on the truck when I purchased it. No more plug boot/wire melting issues. Tucked the pipes next to the frame and through the center crossmember and couldn't be happier. No leaks either.
Mark
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 02-23-2009, 12:40 AM   #14
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Headers?????
I agree with others, you most likely have headaches with cheap headers. Go with very nice headers like the Sanderson's or stay with the rams. However, for the minimal gains that a $400 set of headers will give, I don't consider them worth the investment for myself. They look great, and I were building a show car/truck they would be must, but for a driver, the horns are the way to go, IMO.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-22-2009, 03:21 AM   #15
spinning wheels
spinning wheels's Avatar
Re: Headers?????
Headers have come a long ways in the past few years. With ceramic coating and header bolts like super 8s, with thicker gauge metal material. Leaking exhaust are becoming less of a problem. You might look at some block hugger headers. But check and see if they don't dump right on top of the engine mounts.
As for heat, the stock cast iron exhaust manifolds, will retain much more heat under the hood, than ceramic coated headers will.
Plug wires, again checkout some of the streetrods. New and better wire guides are available that protect the wires and look really cool.
In the end, try out whatever you like. You can always change it later.
Where you looking for Chevelle headers due to the truck being slammed?
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-23-2009, 09:32 AM   #16
westofb
I really hate wet sanding!
westofb's Avatar
Re: Headers?????
you 1st asked about 3/4 length headers from a chevelle, would they fit. I just installed a set on my buddies 69. They are not a simple bolt on, they required switching motor mounts (and the brackets they mount to), we had a junk 85 chevy pickup to use for our parts. We were switching motors, so swapping out the mounting plates/mounts was no big deal. The reason we had to change the mounts, was that the front tube on both sides would make contact with the motor mounting bracket. I'd post a pic of installed motor if I could figure out how to....lol.
westofb is offline   Reply With Quote
Old 02-23-2009, 09:42 AM   #17
70C10Step
70C10Step's Avatar
Re: Headers?????
Thanks for the info! I think I will try the Rams first! I do plan a 5.3 install down the road so I will save some money for now.
All Toys:
Old 02-23-2009, 06:35 PM   #18
Indyuke
Re: Headers?????
I'm with vectorit. I've had full length headers for some time with no problems. But it's just not easy to route the plug wires around them or work around them. As soon as I find a set of corvette rams I'm tossing the headers and putting in a new exhaust system.
Indyuke is offline   Reply With Quote
