Old 02-22-2009, 03:47 AM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
idea
ok well i found out my truck will start if a put a little bit of fuel into the carb but now im wondering is there a way that i can wire a momentary switch up to the fuel pump to like prime the engine
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 02-22-2009, 10:53 AM   #2
shadetree
shadetree's Avatar
Re: idea
Why not fix the problem? It sounds like the accelerator pump on your carb (asuming it isn't fuel injected) is bad. A vacuum leak could be part of this issue, as could ignition timing/plugs/wires/cap & rotor, ect.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 02-22-2009, 11:15 AM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: idea
Unless you've added a electric fuel pump which should be activated soon as the key is turned on, It will be hard to hook a momentary switch to a mechanical pump.
Sounds like the two welch plugs in the bottom of the float bowl, They start leaking fuel out of the bowl into the intake when the engine sits for long periods (over night). Then the engine must be cranked over enough to re-fill the fuel bowl before it will start. These leaking welch plugs can also cause bad fuel mileage.
The fix is remove the carb and cover these two welch plugs with JB-Weld letting cure then re-install.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-22-2009, 12:45 PM   #4
pokethesmot
Re: idea
well here is my problem no fuel enters my engine when i crank it only when its running can you see fuel go into it by the fuel filter and for fuel milage i get about 11 mpg
Old 02-22-2009, 01:03 PM   #5
Restrorob
Restrorob's Avatar
Re: idea
Well,
With the rest of the story now revealed, Replace the accelerator pump as shadetree suggest.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-22-2009, 01:34 PM   #6
pokethesmot
Re: idea
now the accelerator pump is just the fuel pump right?
Old 02-22-2009, 01:43 PM   #7
54Caddy
GM Addicted
54Caddy's Avatar
Re: idea
The accelerator pump is the pump in your carburetor. What kind of carb are you running?
54Caddy is offline   Reply With Quote
Old 02-22-2009, 01:53 PM   #8
pokethesmot
Re: idea
q jet
Old 02-22-2009, 02:06 PM   #9
54Caddy
GM Addicted
54Caddy's Avatar
Re: idea
Go down to a parts store and get you a rebuild kit for your carb. Or simply just get the accelerator pump. Or if you have the money it is worth getting an edelbrock carburetor they are great carbs.
Old 02-22-2009, 02:38 PM   #10
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: idea
powerdriver 1958 is offline   Reply With Quote
Old 02-22-2009, 02:50 PM   #11
Restrorob
Restrorob's Avatar
Re: idea
Also, Take all the numbers off your carb with you to get the proper kit/pump.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-22-2009, 02:40 PM   #12
pokethesmot
Re: idea
when i pump the gas all the lincage and stuff to the accelerator pump moves but like still i see no fuel goin into the carb
Old 02-22-2009, 02:49 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: idea
Once again, it "sounds" like the accelarator pump in the carb. If you don't think you are capable of replacing the pump, see if you can't find someone local that can help.
We don't mind giving advice, but you should be willing to accept it if you ask....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-22-2009, 03:04 PM   #14
pokethesmot
Re: idea
i wasnt not accepting it its just powerdriver asked in that pic think if the linkage was good
Old 02-22-2009, 03:09 PM   #15
powerdriver 1958
Kid's Mechanic
Re: idea
If you try to rebuild yourself here's a link http://www.4wheelnoffroad.com/qjet.html
Old 02-22-2009, 05:12 PM   #16
gafiredog
Re: idea
mine was doing the same thing, put a rebuild kit in it, does fine now.
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 02-22-2009, 07:18 PM   #17
powerdriver 1958
Kid's Mechanic
Re: idea
Poke, the priming idea is a bad one.One backfire and you have a fire that you may not get out.I hope you don't take that the wrong way,just to many things to go wrong.Don't want anybody hurt.
Old 02-22-2009, 08:20 PM   #18
pokethesmot
Re: idea
oh since all i have to do is rebuild the carb then i don't plan on doing this idea
Old 02-22-2009, 09:40 PM   #19
willett
Another Day, Another Dollar
willett's Avatar
Re: idea
you'll shoot your eye out kid
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-22-2009, 11:01 PM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: idea
That too funny.
Let us know if you need any input Poke.
Articles-
"Refining Sierra"
