02-23-2009, 03:31 PM | #1 |
Idea for future suburban project
For my next build, I want to do a suburban. I'm debating on whether to go 2wd or 4wd. I obviously like the low look of the 2wd, but I like the practicality/go anywhere that a 4x4 offers.
I'm also going to set this up for pulling, so 3/4ton running gear. I was kinda thinking to get the best of both worlds, using a later model 3/4 ton front suspension (IFS) and lowering that. Has anyone on here swapped in a 4wd IFS into a 67-72? BTW I'm it will also be diesel powered (may depend what I can find, maybe a cummins, 6.5L, or Duramax) Anyways, I'd like to here thoughts/concerns about the 4x4 IFS swap and picture/details if anyone has done it. |
02-23-2009, 05:10 PM | #2 |
I am a Referee of life.
Re: Idea for future suburban project
I doubt many have done the IFS 4X4 into a early truck.The late model guys building trucks for off road use tend to convert to solid axels.That may make a IFS easier to find and afford but Unless you're going offroad your probably wasting effort.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-23-2009, 06:46 PM | #3 | |
I have a radical idea!
I have '97 K3500 parts truck that came with a 6.5TD and 4L80E,, and I thought about that swap too, but the frames are some much different that I think most feasible solution would be to find a rolled over, but still running 4 door (ext cab may work?) K2500 (or Dodge if you want the Cummins) and put the the 'Burb on the chassis. You would probably have to cut the frame to get the right length, but I see no way of putting in the IRS set-up without cutting the frame and mating it to the 67-72 frame. Even then, the later frames are so much wider that it would be a funky transistion.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-23-2009, 08:23 PM | #4 |
Real 4x4s dont have IFS, Just my opinion, I have owned both kinds and the sraight axle wins hands down, now if you are talking about AWD like in an astro minivan or an Eagle Talon the IFS is alright, No self respecting wheeler "puts" IFS under there rig. use the stock frame, and put a dana under the front, I prefer the 60's
02-23-2009, 09:55 PM | #5 | |
Ackattack, I think you are right about the Dodge having a SFA.
02-23-2009, 08:27 PM | #6 | |
02-23-2009, 09:23 PM | #7 |
Rods
i want 4 wheel ifs awd for my sub/Tahoe build
02-23-2009, 10:07 PM | #8 |
IFS works just fine for slippery roads, and it ride nice and smooth. I have ideas about a burb with IFS.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 Last edited by ERASER5; 03-03-2009 at 07:23 PM. |
02-23-2009, 10:17 PM | #9 |
J'ville Junkman
Regardless of which direction you go, burbs are awesome.
You might need two, a 2wd and a 4wd. Good luck.
72 3/4t Suburban 402BB (Daily driver for 8 years) 68 GTO (never ending proj) 91 Kawasaki ZX-7R 57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans) 73 Corvette (17 yr old daughter's: Another project - what's wrong with me?) 53 Willys M38 |
02-23-2009, 10:22 PM | #10 |
Yeah, i know for wheelin that straight axle works better (I'm looking into getting another jeep too ) A suburban is WAY WAY to big to do any kind of wheelin in these parts (heck my old grand cherokee was almost to big for some trails at times)
I'm going to lower the 'burb with 4wd IFS I mainly think I want it so I can go over the passes and what not whenever I need to. |
02-24-2009, 01:24 AM | #11 |
I understand what you mean. I use mine a little differently, IFS is alright, just not my cup of tea. and on a Suburban seems like alot of extra work for such little extra comfort and ride, I just thought that welding in a crossmember or spring perches would be alot easier that frame swap.
This is what I use my 4x4's For. J's, "The Small Construction Company" The '04 6.0 was mine, until I replaced it with a 2500 HD (I now have IFS ), The '99 7.3 Flatbed has 263,000 on it, almost all with my dumptrailer on it's ass, 8-10,000 pounds loaded right!! |
02-24-2009, 03:39 AM | #12 |
i think finding a complete roll-over d-max truck and putting the body on that frame would be the way to go for the ultimate DD/tow rig. even with some minor w.b. changes, i think it would be way easier to do the body swap rather than graft in the ifs to the early frame.
72 4x4 dually, 454/sm465/np205, d44/d80, 12v hyd dump stake bed. 71 2wd shortwide, 5/6 drop, 350/th350 "driver" |
