WTB this ad
CPP narrowed track width drop spindles...
I got my new issue of Classic Trucks in the mail today and there was an article about CPP's new modular dropped spindles. The article claimed that they allowed the use of larger diameter rotors/calipers (or stockers) as well as narrowed the track width 1" per side and provided 2.5" of drop. I searched their site and the info I saw claimed that they provided 2" of drop and narrowed the track width 1 1/8" per side. I'm generally 100% ECE when it comes to drop parts but the possibility of a narowed track width for $299 sounds interesting...Anyone tried these yet? Opinions? Comments??
http://www.classicperform.com/NewPro...op_Spindle.htm |
#3 | |
Re: CPP narrowed track width drop spindles...
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
I'm interested in the answer to this question also.
Junior Member
I have them on my 67. They did pull the wheels in about 1" per side. They are a 2" drop spindle (not 2.5"). I got the standard size rotors (not the big brake setup). They would not work with my old 5x8 rallys and my buddy had to grind a little on the A-arms.
BlahBlahBlah
I plan on getting a set of these...why wouldnt they work with your 15x8 rallys?
WTB this ad
I'm considering trying to get a 9.5" wide wheel under the front of my next 72 project. Narrowing the track width would help cut down on the amount of offset I would need. In theory, I could get a 9.5" wheel under there with about 4.5" of BS instead of 5.5" of BS (which is what I was figuring/guessing to begin with). I'm not sure how large of a diameter wheel I'd need to keep all the control arm clearances issues at bay...I'm guessing a minimum of 17"??
I also prefer to buy from ECE, but their spindles don't narrow the track width...But I do know that theirs will fit and they have excellent customer service. |
I had 18's on my 74 (18x8 w/5.25"BS using 3" spindles) & they still rubbed the a-arm. The only difference diameter makes is where the rim contacts the a-arm. Smaller diameter rims contact the a-arm closer to the BJ where a larger diameter will contact the a-arm closer to the shock mount.
#9 | |
WTB this ad
![]() ![]() On a side note...Are these the same spindles/brakes that there was a thread about a while back? It seems like there was a thread checking interest in larger brakes for our pickups and it was being monitered(followed up on? commented on, )by someone from CPP? |
#10 | |
I started a 'cheap big-brake' thread about a system I was trying to convince a manufacturer to build for us DIY truck guys. CPP had no interest in this idea when I originally contacted them about it but did post info later in the thread that they were soon going to market their brand 13" brake 'kit'. CPP is marketing theirs. The guys that built my DIY style set-up aren't marketing them but seem to have the customer service routine down pat vs. what I've read about CPP in the review forum.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-24-2009 at 06:42 PM. |
Junior Member
To elaborate, this is a common problem for all drop spindles; not just CPP's.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-24-2009 at 01:35 PM. |
Happy to be here
![]() Join Date: Mar 2000
see ten- It might be a good idea to contact CPP and ask them. They have some very good product, but not so much on customer service. Read the review forum for more details on that subject.
Please keep us informed as several of us hav been considering that as an option.
I have these spindles with their big brakes. I should have them mounted in the next few days. I can measure track width & try to post a couple of pictures if it would by helpful.
#15 |
WTB this ad
#16 |
BlahBlahBlah
It sounds like these may not work for me either. 15x8 wheel with 4.25 inch backspacing will probably rub.
#17 |
I don't have a reference with me, but I always kept this in mind....
All spindle drops, 2" drop may not effect the wheel at all. 2 1/2" require 17" wheel minimum. 3" you are on your own, not sure when or where the arm and wheel will meet. |
#18 | |
I'm using those exact same van ralleys on the front of my 74 now & it has 3" Bell Tech spindles. It did require trimming the a-arm lip near the ball-joint & will still contact the wheel weights before full lock turns. It does not rub making normal left or right hand turns. Those same Bell Tech spindles were on the truck when I had my 18" TT2's on there. 8" wide w/5.25" back-spacing & they rubbed the a-arm before full lock turns. The larger diameter rim required trimming the lip further up the a-arm because they contacted the arm in a different location. Again, it depends on the back spacing of the wheel.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-25-2009 at 08:53 PM. |
#19 | |
#20 |
Junior Member
I put my Intro wheels on (20x8 5" backspace front) and have no rubbing problems. I also have a set of rally wheels (15x7 & 15x8) that I was planning on running. I did't install the brakes/suspension, but if you guys need me to check w/rallys or pics let me know!
#21 |
WTB this ad
Could we have some pics please!!
#22 |
Pics pics please.
#23 |
Junior Member
Just got my issue of Classic Truck mag-Full article on this setup with mult. pics!!!
#24 |
2.5" drop spindles will work with stock 15" wheels and the original brakes?
I would like to order spindles and keep these temporary wheels(6 lug), but what to order - stock replacement or one specificly for disk brakes? |
#25 |
Yes. 2.5" spindles w/stock brakes will work w/15" wheels (depending on the back spacing). If re-using 6-lug wheels, they need to be compatible w/disc brakes (OE 60-70 steel wheels will not work w/later OE disc brakes). You can get aftermarket 6-lug steelies that work w/disc brakes or use 6-lug 4x4 ralleys.
