Old 02-24-2009, 12:45 AM   #1
donelan07
Active Member
donelan07's Avatar
Timing and Back Firing Issues. Pictures
I just got a clean gas tank and new fuel pump put in. Now my truck wont start it just back fires.
Fire out the top of the carb
Bottom of the Fuel Pump. Return line?
Return line?
Where it is back firing from.
_________________________________
1972 Chevy SWB 4x4 350 4speed
donelan07 is offline   Reply With Quote
Old 02-24-2009, 01:07 AM   #2
Infanti
www.infantimachine.com
Infanti's Avatar
Re: Timing and Back Firing Issues. Pictures
Did you fool around with the distributor?Looks like timing is out.
Infanti is offline   Reply With Quote
Old 02-24-2009, 10:04 AM   #3
68gmsee
Active Member
68gmsee's Avatar
As Infanti mentioned, it's possibly a timing issue. Other thing that can cause it are bad valves, badly worn timing chain or gears or even the cam/crank gears out of adjustment.
I would check the timing and have a compression check done.
68gmsee is offline   Reply With Quote
Old 02-24-2009, 12:06 PM   #4
72chevyk10
I built it
72chevyk10's Avatar
SWEET *cough* i mean ow thats bad
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 02-24-2009, 08:46 PM   #5
Infanti
Infanti's Avatar
Give us more info on what you did so far.Was truck running fine,then you changed gas tank and fuel pump and this all happened?Or did you have issues before you changed parts out.
Old 02-24-2009, 09:22 PM   #6
texanidiot25
Eat My Rust
texanidiot25's Avatar
Looks like the 1st fire-ups on my motor before the timing was set
texanidiot25 is offline   Reply With Quote
Old 02-24-2009, 10:57 PM   #7
americanmusc1e
americanmusc1e's Avatar
TRY THIS
do you have a points distributer still?
i managed to put my distributer cap on backwards one time (i put the little peg in the vacumn advance slot and fit and looked alright) and it backfired out of the carb just like that,
we even poured gas into the carb trying to get it to start, all it did was catch my carb on fire
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 02-25-2009, 06:13 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
looks like you do in fact have the correct pump for a non-return system, good.
it is back firing from the throat, timing way off. unfortunately I bet the power valve is now toast. I'll check with wifey and see if I can get parole for this weekend.
first I need you to hit Advance and get a 6.5 power valve and possibly a bowl gasket. I'm all fresh out of both. all I have left is 3.5, a couple 2.5s and 3 plugs (hi-perf stuff).
power valve
http://holley.com/125-165.asp
gasket
http://holley.com/108-83-2.asp
BTW, this would be a good idea. not necessary, but would be nice.
http://holley.com/108-98-10.asp
do not, I repeat DO NOT use these
http://holley.com/26-113.asp
68C15 is offline   Reply With Quote
Old 02-25-2009, 01:55 PM   #9
donelan07
Active Member
donelan07's Avatar
I can't work on my truck this weekend. My brothers wrestling up in Aberdeen for state.
Old 02-25-2009, 10:33 PM   #10
68C15
blood type; Retumbo
68C15's Avatar
OK, now I dont have to feel guilty for not being available. my leave was pulled because I went to Harbor Freight last weekend. she is upset about what I spent.
