02-24-2009, 02:27 AM | #1 |
need help with hotrod choice, S-10 Blazer, or truck???
Well, I wanted a box style truck, and I have a '91, but the wife got it lol. I have a '95 Blazer, my in-laws Blazer threw a rod. It is a 4.3 auto car, so I have a chance to get it back, it was my old Blazer. I'm not sure on the weight of this Blazer, it is a 4dr. I have an engine in a cc midsize truck, weight is 4500lbs and I'm wondering what the Blazer may be. I have a 550hp engine that needs something better than a 4500lb brick.
02-24-2009, 01:16 PM | #2 | |
Unfinished Project Club
Re: need help with hotrod choice, S-10 Blazer, or truck???
Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas 1993 Jeep Cherokee. Looking for a swb chevy 73-87 Last edited by lvschevytrucks; 02-24-2009 at 01:16 PM. |
02-24-2009, 01:35 PM | #3 |
Thanks, I found a 88 S-10 truck I'm looking into. I think they are around 3000lbs, give or take a few hundred, I think I remember hearing like 2700lbs but not clear on that. If your 4x4 is 4000lbs then mine is a little under but thats still way to heavy and not worth it, but it is a nice Blazer, but not worth the time and trouble for the swap I had in mind.
02-24-2009, 02:42 PM | #4 |
Little trick to get those trucks to hook, is turning down the pinion angle on the rear I am thinking turned down 5-6 degrees.
Saw one that was built that had done to it. It just squatted and took off. ran 11. second on street tires.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 02-24-2009 at 02:42 PM. |
02-24-2009, 03:11 PM | #5 | |
I had plans to do that, along with ladder bars. |
02-25-2009, 09:45 AM | #6 |
Thanks for the tip BarryB, I will have to try that on mine.
My truck is kind of a tire roaster at the moment.
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
