Old 02-26-2009, 07:44 PM   #1
jephs422
Scotts ifs for $1395?? Not a group buy..just good pricing.
Okay so here's the deal, I know that 2k-3k is a lot of coin to drop all at once for a front suspension. So we've come up with a way to make it a bit more affordable for the "project minded"
What we are doing is selling our ifs as a component piece at a discount price.
Here's what you will get.
Our complete one piece Scotts Crossmember set up fpr airbags or coilovers. The crossmember will have the rack mounts attached to it as well.
You will get a complete set of Scotts adjustable a-arms; All 4 top and bottom with ball joints pressed in.
Lastly you will get a set of spindles, drop or stock height, your choice. These will be a Mustang II style spindle to allow for a little bit greater choice in aftermarket brakes.
So the only items you need to buy to get you on the road is a rack, brakes, coilover or airbags/shocks, and you are pretty much ready to rock.
Rather than a group buy, I'd rather just make this YOUR guy's pricing. You ca,, me, I'll get it to ya. Remember you NEED to let me know that you are from the 67-72 board.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 02-26-2009, 11:05 PM   #2
68 short step
Re: Scotts ifs for $1395?? Not a group buy..just good pricing.
do you have some pics of this set-up???
-also what rack do you use?
- how much more for front brakes
12.5" or larger w/ 5 on 5 bolt pattern????
-the motor mounts come in a LS version??
68 short step is offline   Reply With Quote
Old 02-27-2009, 01:20 AM   #3
Scottshotrods
we do have pics we will post them friday morning.
The rack we use
power rack is a 88-89 for t-bird rack
manual rack we use is from mavel and it is a mustang rack
the price on brakes we have several sizes
11 inch rotor
12 inch rotor
13 inch rotor
14 inch rotor
15 inch rotor
we have gm calipers and wilwood 4 piston calipers and
6 piston calipers
the brake kits start at $389.00 and can go as high as $2295.00
for the motor mounts we have them in
sbc
bbc
l-s1 thru l-s9
and many other options
our complete price on a
scotts superslam ifs $2395.00 retail
scotts standard ifs $2395.00
power rack you will add $100.00
call us at the shop (805)485-0382
justin
www.scotshotrods.com
Scottshotrods is offline   Reply With Quote
Old 02-27-2009, 12:41 AM   #4
Twisted Minis
Twisted Minis's Avatar
Have you guys ever done any kits for early Mustangs and other cars based on that chassis? I know you guys where doing some fast backs, but I think they where full frame cars. I had a guy asking about MII on his big block car, for better performance and also so he can change his spark plugs. Your set up looks a lot more tunable than the traditional MII, plus I don't like they way most MII kits are put together. I'd rather try to sway him to something more high end.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-27-2009, 01:25 AM   #5
Scottshotrods
we do have ifs kits thru 1923-2009
we have installed our kits on early mustangs with 4.6 mod
motors useing the stock uni-body structure.
Call us at the shop on friday we can get alot more detail
with you.
(805)485-0382
justin
www.scottshotrods.com
Old 02-27-2009, 02:16 AM   #6
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
good timing. i'll be calling tomorrow for a setup for my '50.
IvelDesigns is offline   Reply With Quote
Old 02-27-2009, 12:25 PM   #7
jephs422
I'll be here
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 02-27-2009, 12:40 PM   #8
jephs422
Well I'll need to go take a front end apart to get bare pics....but if you haven't seen a picture of our ifs, here is a complete unit for a 67-72 (less brakes); So put your fingers over all the other parts so you can only see the crossmember, a-arms, and spindles.......and that's what ya get....
found some pics of a 67 install, so here's exactly what you'll have installed.
Note that this ifs will get a full 10" of travel....
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 02-28-2009, 01:30 PM   #9
Scottshotrods
We also have the a-arms in polished
s.s.We can do a huge discount on
polished a-arms discount.
Standard price is $500.00 when you buy the ifs.
Your price will be a $300.00 when you buy the ifs as long as you are
member on the site.
Justin
Old 03-09-2009, 02:57 AM   #10
six5
six5's Avatar
Will other A arms work with your cross member? And can I purchase just the cross member by its self??
Thanks......
six5 is offline   Reply With Quote
Old 03-09-2009, 10:47 AM   #11
jephs422
Thanks......
Sorry, only our a-arms or a custom set will work.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 03-09-2009, 05:23 PM   #12
mygr8ride2000
would you be willing to sell just the front crossmember. i alreadly have alot of the other components.
kyle
mygr8ride2000 is offline   Reply With Quote
Old 03-09-2009, 06:32 PM   #13
jephs422
kyle
I can do that, but just remember you'll need a set of our a-arms, or you'll need to fabricate a set.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 03-09-2009, 07:35 PM   #14
six5
six5's Avatar
Jeph can someone purchase just the a arm ball joint ends from you? I would like to make my own A arms to save some cash, ect. Please PM the price of just your cross member shipped to Reno, Nevada 89523. And if I can purchase just the ball joint ends a price for that as well.
Thanks.......
Old 03-10-2009, 12:46 PM   #15
jephs422
PM's sent to everyone.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 03-24-2009, 02:56 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Other than having to be welded in, how does this compare to a dropmember? I am looking for a 4WD Blazer and plan on converting to 2WD using a PB Dropmember or this crossmember. How low would this put me with stock height spindles and 31" tall tires? How much difference do drop spindles make (other than having more air in the bags at ride height)
Old 03-24-2009, 03:11 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
Also, can you post some pictures of the polished A-arms?
And a price for this (Superslam) with Slam Re-7 bags (4 for front and rear), Power rack, and a decent cross drilled front and rear 5 lug 12" brake setup.
Old 03-25-2009, 10:56 AM   #18
jephs422
here's a pic of the stainless arms.
A lot of people ask for Chrome instead of stainless, and sorry, we just don't offer it. When we do a "show" front end we use solid bar stainless and polish it in house to a mirror finish.
Pricing on the front suspension as a complete units is $2395.00 plus $100 for power rack (core charge). That is hub to hub, 11" rotors, spindles, rack, all bearings and seals, etc.
For brake upgrades there is an endless amount of options, but for all of our typical upgrades we use Wilwood kits. For example, the upgrade price to an 11" cross drilled rotor, black caliper Wilwood kit is $799.00. For the same kit just non-cross drilled the upgrade is $627.00
We can do up to a 14" rotor and 6 piston caliper.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 03-24-2009, 07:24 PM   #19
jephs422
Well to be honest I really hate "comparing" one product to another. However I can tell you that our products are apples to oranges in that direct comparison.
let me simply tell you what we offer and what we do.
ALL of our ifs systems are built one at a time and built per application. So simply put, you are getting a front suspension built for YOUR truck, not just a 67-72 pickup. If you have a custom frame, custom ride height, custom track, whatever it may be, we will design and build it. If you are looking for a truck to sit low, and ride nice, that's no problem. If you need a truck to tow heavy loads, or to handle the road course, no problem, we will design it.
This doesn't mean that we take a crossmember, rebuild it, and stick a set of arms on it. What this means is that EVERY A-arm is unique. EVERY crossmember is unique. There is nothing pre-built and ready to ship. Engineering and design are Critical in every application.
Aside from the design of the suspension and uniqueness in the way we build things, we are also a one stop shop. When you buy our suspensions, you will get everything you need. And if it isn't included in the price, we will at least have it in stock and available from us so there is no need to shop anywhere else. If you buy a suspension from us, and a column, and u-joints, etc., and something doesn't work........well there is no passing the buck. We will take care of things here cause you bought it here.
Also, we try to package things to keep them economical for everyone. With our system there is no need to go drop $1200 on a set of Air-ride arms. There is no need to go drop cash on eBay for a set of brakes. Hub to Hub WITH power is only $2495.00 COMPLETE.
Now if you were to just buy the crossmember and A-arms at the $1395 price, you are still getting away dirt cheap in comparison, for everything else you need to buy. But as a complete unit, you will save about $500 by the time you are all done.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
