Old 02-26-2009, 10:08 PM   #1
DZL1
One day.....
DZL1's Avatar
Parking/emrgency brake question/problem...
I have a '72 C-10 shortbed fleetside, automatic, 2wd, v-8. From my understanding, the entire parking brake assembly consists of the front cable that goes connected to the actual brake lever. The center, long cable that connects to the front cable via the cable adjuster peice, and the 2 cables that go to each drum brake cable.
Now my question is the long,center cable is also attached to a bar that looks like its not adjustable. This bar is on the passengaer side with the front of the bar attached to the chassis and the rear attached to the cable. Is this bar adjustable?
Now my problem is that i dont have enough of the center/long cable to connect to each brake drum cable. I even removed the cable completly from the front cable and adjuster peice and still dont have enough. I'm about 8-10 inches short. I cant seem to remove it from the bar described above.
So now i'm stuck. Any and all help is greatly appreciated.
DZL1.
DZL1 is offline   Reply With Quote
Old 02-27-2009, 01:28 AM   #2
DZL1
One day.....
DZL1's Avatar
Re: Parking/emrgency brake question/problem...
No replies....now I know I'm in trouble.
DZL1.
Old 02-27-2009, 03:48 AM   #3
CCCC
CCCC's Avatar
I am having difficulty picturing what you mean about the bar that is attached to the chassis at its front and to the cable at its rear. I do not have C10 (other than Blazers, as such), and those emergency brake setups might be differently arranged than the pickup. It is cold out there tonight or I would go look for your sake.
However, my basic memory of these setups on most or all of the these trucks I have worked upon is that the front cable (from the pedal mechanism) has a threaded rod at its back end, and that this rod goes through a "V" shaped flange of some sort, backed up by an adjusting nut (for cable length/tension). In some manner, the cable arrangements to the rear brake units are attached to both tips of the 'V" piece, or maybe actually it is a one piece cable that rides in a groove in the "V" shaped flange and goes out to both brake units.
There may be a guide piece or some other attachment to that front cable - up toward the front of the cab - to keep the cable in place and direction - but am not certain of that.
If you do not get a useful answer here by tomorrow eveneing, I will have looked at one of the Blazers and at a C20 and should be able to tell you something definitive at that time.
Good luck.
CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 02-27-2009, 09:40 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Use the catalog pic in LMC site to describe your problem. Sounds like you're saying cable #2 is not long enough? IIRC, the only part that is adjustable is cable #1. All the rest are stationary.
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=154
68gmsee is offline   Reply With Quote
Old 02-27-2009, 10:15 AM   #5
DZL1
One day.....
DZL1's Avatar
CCCC, Thanks for taking the time to reply. 68gmsee has sent a link to the exact part i'm refering to.
68gmsee, thanks for helping once again. The part that im refering to is #5, Park brake cable guide kit. And its not adjustable. Sooooo, now I'm really stumped as to why my cable wont reach!
Old 02-27-2009, 01:17 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Nope, that's not adjustable, but have you lengthened the end of cable #1. That's the only one that's adjustable.
Make sure that you clean and spray lube the cables where it has the wire loom around it. Also, remove the rear drums and check that the ends are installed correctly as per pic.
Old 02-27-2009, 09:07 PM   #7
Sammy
Is it possible he has a shortbed cable installing it on a longbed truck? Hence the lack of cable length?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-27-2009, 09:40 PM   #8
DZL1
One day.....
DZL1's Avatar
68gmsee, remember I have cable 2, the long one, diconnected from cable 1, the one attached to the parking brake.
Sammy, I do have a shortbed truck.
Guys again thanks for your help. I'll just keeb racking my brain as to whats going on.
DZL1.
Old 02-27-2009, 10:12 PM   #9
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
I think cable #2 is made in some different lengths depending on your chassis length/rear brake setup. The LMC catalog shows a bunch of different part numbers for that cable.
My guess is that you have the wrong cable #2 in there. It's possible you have the wrong #3 cables too. When I replaced my rear brake cables, there was a different part number for TH350 and TH400 trucks with the same rear end.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 02-27-2009, 11:05 PM   #10
DZL1
One day.....
DZL1's Avatar
Hey Lugnut, if I'm reading correctly, they only show 1, number 2 cable available for the short bed truck. Now as far as the rear cable goes, I have coil springs in the rear. And the book only shows 1 version for 2wd, 1/2 ton, swb, 67-72, with coil springs. Correct me if I'm wrong, but that's what I came up with.
This sucks.
DZL1.
Old 02-28-2009, 02:14 AM   #11
Lugnut64052
DZL1.
Hmyeah, you're right, now that I examine the listing closer.
I can't think of any other problem that would cause a whopping 8 to 10 inch length shortage.
Was it just hanging there un-hooked up?
Guess you might just have to get one made like 72blue suggests.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 02-28-2009, 12:12 AM   #12
72blue
72blue's Avatar
you might have to get a custom one made. Around my parts, a clutch and brake parts place has the ability to make them up, not cheap, but they will make you one exactly like one you bring in(but longer), I bet there is a place that will do that in your area. If you have to get one made rather than some kind of simple fix or adjustment, that does suck.
72blue is offline   Reply With Quote
Old 02-28-2009, 12:58 AM   #13
DZL1
One day.....
DZL1's Avatar
Thanks for the idea 72blue.
DZL1.
