02-28-2009, 01:32 AM | #1 |
You who have completely rebuilt your rigs!
I am needing someone who had installed their doors and done extensive restoration work to their blazers. I am trying to get the drivers door installed and don't believe it is possible with the geometry I have now. I did the pass door myself and it turned out ok but the more I adjust, the more I get to feeling that something else is out of kilter. I have included pics for the picture junkies (I am too). I reinstalled new body mounts earlier on, and rebuilt the door hinges, could be part of my problem. The body man 50 years experience replaced the outside rockers , small piece of floor on this very little rust vehicle. See the pics. I can't seem to get it adjusted so that the bottom seam is strait AND it does not touch the rocker with the door corner at the front edge. I am asking this...I have 4 shims under the front drivers side floor body mount and one under the body mount nearest the B pillar. This was exactly as I found it and replaced exactly. I think I need to remove the 4 shims on the front mount. Are these shims for adjusting the doors or are they mostly for alignment of the top to the body? When we replaced the rockers, we did so with the new body mounts inplace because the old ones were toast and we had the top on and bolted down to hold everthing in place while the cutting and welding was going on. I know that you guys say to have patience but I did have this question for those of you who have had the cutting torch in your own hands so please help me out and tell me everyting is going to be ok, and the sun will come out tomorrow, and the world will have peace, and Obama will now ruin the country...oh sorry, I got carried away.
02-28-2009, 06:28 AM | #2 |
The LuvShack Garage
Re: You who have completely rebuilt your rigs!
My pass. door lined up perfectly, driver did not,
after we removed the tub it was almost perfect. I say it just needs an extra body mount shim
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-28-2009, 09:37 AM | #3 |
Try putting your vent window in, sometimes that will move the door frame allowing you to change the door alignment. Make sure your vent window is strait, don't ask how I know
Nice truck BTW
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-28-2009 at 10:00 AM. |
02-28-2009, 11:45 AM | #4 |
The LuvShack Garage
Also if your using repop hinges they may need the
holes slotted a little more. They are not perfect
02-28-2009, 01:44 PM | #5 |
02-28-2009, 08:31 PM | #6 |
02-28-2009, 02:21 PM | #7 |
I'm not an expert, but I do work in the field. First thing is first though, you need to put the top on the Blazer and tighten it down. Once you have done that, you might see that you'll need to shim the body mounts. If you don't need to great, but something tells me that the body mounts under the middle of the cab need some adjustments. Once that is done you should have an easier time adjusting the doors. Hope this helps. Mario
02-28-2009, 07:01 PM | #8 |
Active Member
Luv is right no matter if your hinges are re-pop or not, hog the holes of your hinges a bit, it's amazing the room for adjustment you get. A body guy I know has made himself a 4 foot bar that has adjustable hooks that fit inside the door (with the door panel off and the hooks adjust and tighten as needed. He got up on the tub of mine and tweaked the door until is lined up perfectly and then I just tightened the bolts. there are lots of tricks out there to get things lined up right. my doors latch now with a gentle push.
02-28-2009, 07:13 PM | #9 |
The LuvShack Garage
Oh yea, thunder is right, the top helps alot too.
02-28-2009, 08:40 PM | #10 |
The LuvShack Garage
What I meant was I obviously was off on the body mounts
somewhere. Just the slightest bit of shimming can adjust it more than you think. I had a new body mount kit and frame was perfect, however that does not mean a perfect fit. We pulled the tub and the door fixed itself. Which meant it had to be in the body mounts and a shim could have fixed it.
02-28-2009, 11:03 PM | #11 |
Got it!
03-01-2009, 03:38 AM | #12 |
I know you guys do great work. But the door, hood etc. were a far cry from a perfect fit when they were built new. They were never intended for show trucks, and were put together pretty sloppy.
03-01-2009, 09:29 AM | #13 |
Gotta agree, it was and still is a truck
03-01-2009, 09:40 AM | #14 |
I've seen more than a few times trying to adjust doors on a blazer with a full removable top be next to impossible with the top off. There is alot of flex in the body with the top off. Put the top on, tighten it down and see where it's at. Adjust the doors with the top on and then take the top off. You'll notice a change.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
03-01-2009, 06:55 PM | #15 |
Set your rocker and A pillar gap, then adjust body shins to set your door to quarter gap. Don't forget to make sure your wedges are installed when finished
Mike Redpath |
03-01-2009, 11:00 PM | #16 |
My question now is this, if I put on the top and get the doors aligned and then take the top off, is the doors then going to come out of line? I am about to say finished and ride, the shims I moved yesterday seem to have gotten me closer than I was! There may be a little angle gap at bottom of door left when I am finished. I really appreciate you all posting!
03-03-2009, 08:35 PM | #17 |
Last question still stands...
