Old 03-02-2009, 12:40 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Gauges?
What size are the stock gauges in an 84? The big ones and the small ones. I want to get some new gauges soon and need to know what sizes I need. Also, how/where do I hook up a gauge that isnt stock(Like tranny temp, etc)?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-02-2009, 01:13 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Gauges?
You are probably looking at using the 2 1/16 gauges if you install them from behind, but you can fit 2 5/8 if you install them from the top.
Transmission temp usually gets installed in the pan, or inline on one of the lines to the cooler.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-02-2009, 01:19 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Gauges?
A 5" gauge for the spedo and tach will fit with the domes removed on the back of the bezel and a 2 5/8 for the smaller with the same modifications as larger gauges, also the white cluster will need to be modified, and for the unoriginal electric gauges will need a switched power, ground, and a sender wire
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-02-2009, 02:24 AM   #4
thirdstreettito
Resident of Here
Re: Gauges?
Thanks! I know nothing about wiring/gauges etc. Is there guide on how to do it? I am also going to be running a 3 gauge holder under dash(diesel gauges). Do aftermarket gauges have the warning lights? Like low coolant etc. I'm great at body/paint/mechanical but am dumb when it comes to sending units, wiring, etc. But I have wired houses so I do know a bit. All help appreciated!
~Bradley~
Miss having a truck
Old 03-02-2009, 08:31 PM   #5
thirdstreettito
Resident of Here
Re: Gauges?
Ttt
~Bradley~
Miss having a truck
Old 03-02-2009, 08:36 PM   #6
flamingbig10
6.0 powered square
Re: Gauges?
a hanes wiring diagram will help a lot on the wiring, I don't know about the warning lights
Aaron
Old 03-02-2009, 09:01 PM   #7
ca180
tryin to get laid
Re: Gauges?
http://www.73-87.com/7387garage/inte...ge_surface.htm
ca180 is offline   Reply With Quote
Old 03-02-2009, 09:09 PM   #8
silvereagle07
silvereagle07's Avatar
Re: Gauges?
Here is a couple of links to check out.
http://www.73-87.com/7387garage/inte...s_recessed.htm
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-02-2009, 09:40 PM   #9
thirdstreettito
Resident of Here
Re: Gauges?
Thanks guys.
~Bradley~
Miss having a truck
Old 03-02-2009, 10:16 PM   #10
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: Gauges?
im taking this on soon i will keep you guys posted on my progress but im using smaller guages then the article i think i have a good idea i had to use the smaller guages because i got them real cheap.
staggerd86c-10 is offline   Reply With Quote
Old 03-02-2009, 10:19 PM   #11
thirdstreettito
Resident of Here
Re: Gauges?
I'll be buying a 3 3/8" tach soon, I'll post pics when I install it. Your links really helped me. Thanks
~Bradley~
Miss having a truck
Old 03-02-2009, 10:50 PM   #12
staggerd86c-10
Re: Gauges?
yeah i got the 3 3/8 tach and speedo lets see how it comes out.
Old 03-03-2009, 08:48 AM   #13
thirdstreettito
Resident of Here
Re: Gauges?
Well I am mounting the tach sideways on the dash(to the right of the gauges). It is a Diesel tach(max 6k rpm). It'll look sweet!
~Bradley~
Miss having a truck
