Coil springs
Wondering if anyone knows approx. what the stock height (measurement) of a front coil spring should be on an 80's model half ton? Kinda curious cuz I got a set of coils from a buddy of mine and they measure 13 inches and have 6 coils. He thought they were stock but they look short to me. I'm wanting to put them in my 84 swb that will have a big block and already has 2" drop spindles. Think the big block is about 100lbs heavier than a small block and if those springs arent stock, might put the truck a little lower in the front than Im wanting. I would measure the ones in the truck now but the previous owner cut them so short, when I jack the truck up the springs almost fall out so I have nothing to go by. Thanks in advance for any input.
Re: Coil springs
Ill have a set at the casa. If someone else doesnt get you a number by tonight ill post it up.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Coil springs
I cant tell you the exact height but six seems small to me too.. when i did my 86 im sure it was seven or eight
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Coil springs
FYI....I just bought a pair of "stock" frt springs for my SB 1/2T they measure 14" tall & 8 coils.
Gene ![]() |
Re: Coil springs
Here are some specs I found when looking for heavy duty OEM replacements:
TRW number CS6454 INSIDE DIA.= 3.676 in. BAR DIA.= 0.83 in. FREE HEIGHT= 13.61 in. SPRING RATE= 1060 Lbs./In. LOAD= 3841 Lbs. LOAD HEIGHT= 10 in. END 1= PIG TAIL END 2= TANGENTIAL NAPA Item#: NCP2772074 Type:One Tangential End; One Pigtail End I.D.:3.676" Wire Diameter:.83" Load Height:10" # of Coils:8 Design Load:3841 Spring Rate:1060 Free Height:13.61"
- Greg |
Re: Coil springs
Thanks for the replies gentlemen. Those spring specs will come in handy. If im not mistaken, half a coil is about an inch of drop so Im thinkin the ones I have are probably about 1" or 1 1/2" drop. Pretty sure they're not stock now. Im gonna try em and see. Thanks
