03-02-2009, 02:33 PM | #1 |
Fuel line
I'd like to replace the stock metal tubing with either -6 braided AN or something equivalent in inside diameter from the tank to the engine. I've seen aluminum hard line as well. I've read that fuel will eventually start to seep through braided line and make the vehicle smell like fuel all the time, is this true ?
Whats best to use and will pass tech inspection ? What works for you ?
1977 GMC Sierra Grande |
03-02-2009, 08:33 PM | #2 |
Re: Fuel line
Braided line will need to be replaced periodically. I use nomex braided...but I replace it every couple of years. For #6 I'd use 3/8th stainless brake line. Aluminum scares me...it will work harden and fail at the connections.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA Last edited by bigjimzlll; 03-02-2009 at 08:35 PM. |
03-02-2009, 09:45 PM | #3 |
Re: Fuel line
1/2 inch stainless and your done forever pretty much and use the stainless connectors.
Built chevy tuff! |
03-03-2009, 10:48 AM | #4 |
Re: Fuel line
You can use teflon covered w/braided stainless steel. It's a bit more expensive but you wont have to replace it. I would run 8AN.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-03-2009, 02:23 PM | #5 |
Registered Truck Offender
Re: Fuel line
I would agree 1000000% There is this thing called the 'Faster, faster, faster' bug and it BITES,, and it bites with a VENGANCE!! Eventually you will outgrow the -6 and need -8 anyways,,,, don't wast the $'s on fittings you will eventually need to replace. There too stinking expensive for that! And if anyone gives you crap about not needing that much fuel line right now,,, tell them your setting the truck up for when E85 is all that's available! I ran Aeroquip -8 for about 6 years and no leaks, seeps or weeps. Then I switched the car to alcohol for a couple of races to see if I could tolerate it. (didn't like it and switched back to gas) and in a year I had to replace all the lines. It may have already been brittle, or the alcohol hardened it,,, don't know. The truck has the same an-6 aeroquip line I put on it in 1998. I'm sure 10 years is pushing it, but no hint of leaks yet.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
03-04-2009, 04:18 AM | #6 | |
Re: Fuel line
Also, if I go with -8 I know I'm gonna need at least the same size on the inlet side of the pump (Carter 8 PSI electric). This is a 73-87 truck with saddle tanks. Should I be looking at modifying the sending unit for a larger diameter pickup tube ?
03-03-2009, 08:59 PM | #7 |
Re: Fuel line
Marv D the issue with the hose isn't that they actually leak fluid, it's that the fuel vapors will escape from the line and stink up the garage. That is the problem I had. I now run Aeroquip TFE line. My garage stunk until I switched the hose.
03-07-2009, 09:42 AM | #8 |
Re: Fuel line
Can you use the standard aeroquip fittings with TFE -8 line?
03-07-2009, 10:05 AM | #9 |
Re: Fuel line
No you need different fittings. They are steel fittings. They are a bit more expensive then the standard aluminum ones.
03-07-2009, 11:03 AM | #10 |
Re: Fuel line
That's pretty interesting. I've never experienced that myself. I run C-14 in the Nova and it's a very aeromatic fuel,, never smell anything in the shop unless the drum or fuel cell has been opened. Having a rubber tube core, then a reinforced braid, another rubber liner, then the stainless braid,, I'm very surprised anything (especially vapors) can weep out,,, but anythings possible. I would think that would be a huge fire danger issue.
03-07-2009, 05:17 PM | #11 | |
Re: Fuel line
03-07-2009, 06:29 PM | #12 |
Re: Fuel line
Right now the pump seems to prime itself fine. It's mounted level with the top of the pickup tube on the sending unit. My worry about the 1/2 inch pickup tube was that the pump would have a larger volume of fuel to pull up from the tank, which means it would work harder. It may not even be able to prime pull a vacuum and prime itself with that much volume in the inlet tube.
So it looks like I need to stick with the 3/8 ID tubing or sump the tank to run -8 AN ? I'd rather not go to an intank pump because I just bought and installed this Carter inline pump.
03-07-2009, 10:16 PM | #13 | |
Re: Fuel line
03-03-2009, 10:45 PM | #14 |
Re: Fuel line
does anybody run the black lite weight hose?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-03-2009, 11:02 PM | #15 |
Re: Fuel line
I have 1/2" stainless steel tubing hand bent with a pipe bender and its a pain but its tough all stainless ferrels and connectors,5 gallon cell ,holley blue,it works fine.
Built chevy tuff! |
03-07-2009, 02:11 AM | #16 |
Re: Fuel line
I am also curious about how well this works, I like the look so much better than old braided steel. The Aeroquip Startlite looks really clean, and I think I can get it locally.
03-07-2009, 03:26 AM | #17 |
Re: Fuel line
Still wondering what I should do with the pickup for my tank. Will welding a length of 1/2 ID stainless tubing into the sending unit to replace the stock small diameter tube work for me ? This seems like the most logical move if I am going to run -8 from the pump up to the motor.
1977 GMC Sierra Grande Last edited by Pyrotechnic; 03-07-2009 at 03:27 AM. |
03-07-2009, 10:26 AM | #18 | |
Re: Fuel line
03-07-2009, 11:09 AM | #19 | |
Re: Fuel line
03-07-2009, 08:58 AM | #20 | |
Re: Fuel line
I have a friend that has some brand of light weight black hose with black light weight fittings I'll try to find a pic of it. It looks awesome but is expensive!
03-07-2009, 01:38 PM | #21 |
Re: Fuel line
That would be really cool, that is the stuff I am talking about. And if I can get it locally, I can put it on the company account
03-07-2009, 01:02 PM | #22 |
Re: Fuel line
One of my cousins modified the pickup in his Camaro tank by welding the 1/2" tubing into the stock tube location. Last I heard he was on his 3rd pump and couldn't get more than a couple of race days out of them. We couldn't figure out why because he had new 1/2" line for his whole system and a high flow filter so not much for restrictions. I bet if he had installed a sump on his tank there would have been no more pump problems.
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350 1.83 60' 13.14 @ 100 on motor 1.49 60' 11.52 @ 116 w/150 shot 1952 Chevy truck project 1980 Z28 Camaro 1967 Camaro drag car 10.60@126 |
03-07-2009, 05:13 PM | #23 | |
Re: Fuel line
Aeromotive now sells a pump/sump kit all in one. You can cut a whole in your old tank and weld in this kit. The pumps are built into the sump, pretty neat idea.
03-09-2009, 08:13 PM | #24 |
Re: Fuel line
Just remember, if you start with Russell, STAY with Russell. Seems most other brands (aeroquip, Earls, Jeggs, Speedway) are compatable. But Russell seems to have more leaks when you mix and match fittings of various brands. Stick with Russell all the way through or don't use them at all seems to be the consensus.
03-09-2009, 11:40 PM | #25 |
Re: Fuel line
So far everything I have is Russell. Good info about not them not mixing with other brands, I was not aware of that. Kind of strange for something that is supposedly made to a common specification.
