Old 03-02-2009, 06:35 PM   #1
Storm Chaser
Storm Chaser's Avatar
Crew Cab Owners- I need your assistance.
Trying to work out a driveshaft for my crew cab. I have a few shafts on hand, but nothing is close...
First of all can someone confirm that the layout goes like this (starting from the transmission)...
1- Slip yoke
2- U-joint
3- Intermediate shaft (with carrier bearing at the end)
4- Slip yoke
5- U-joint
6- Rear shaft
7- U-joint (at rear diff)
Also, can you give me the following measurements so I can take them to the yard with me (Automatic tranny btw)-
1- rear shaft length from center of U-joint at the rear to the end of the slip.
2- intermediate shaft length from end of shaft to center of U-joint (unless you have one out of the truck, then you can go to end of tranny yoke). Also, for the intermediate shaft, be sure to mention what tranny you are running.
I have a TH350, a TH400 and a 700r4 available to me, so it'll probably depend on what driveshaft setup I find.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 03-02-2009, 08:38 PM   #2
rigon4
rigon4's Avatar
Re: Crew Cab Owners- I need your assistance.
Layout sounds good but with my 1988 3+3 the th400 is not a slip yoke it is a bolt on yoke. let me go out and take some measurements.
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 03-02-2009, 08:49 PM   #3
rigon4
rigon4's Avatar
center of u joint at trans to center of bearing 38.5 inches
center of joint at slip yoke to center of joint at pinon is 56 inches
the slip yoke is 7.25 inches long from center of joint so rear shaft would be 63.25 inches long form end of yoke to center of joint at pinon
and thats with a th400
as good as i can get with out pulling the rear shaft and thats not going to happen at 10*F outside
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 03-03-2009, 08:49 AM   #4
Storm Chaser
Thanks a ton!
Anyone with the 700r4 that can measure their intermediate shaft? From what I've read, the rear shaft is the same. Would the 700r4 be a bolt on yoke in this application also?
1988 R2500 Crew Cab
Future plans-
Old 03-03-2009, 10:14 PM   #5
SmokeShow
SmokeShow's Avatar
why an intermediate shaft?? Why not just a one piece shaft from trans./xcase to rearend? That's how mine is and how the newer body style trucks are that are crew cab short beds.
C-ya
02 Chevy 2500HD D/A EC SB 4x4
MA SCIII trans, EFI Live, 5" exhaust, 5% tint...
83 GMC K30 Crew Cab Short Bed
06 Duramax & ZF6 (to be installed) and more to come...
SmokeShow is offline   Reply With Quote
Old 03-04-2009, 09:19 AM   #6
Storm Chaser
Mine's a crew cab long bed 2wd. That would be one long driveshaft if it was one piece. Just trying to get the factory setup ironed out.
Out of all the yards near me, I only found one with the driveshaft intact, so I bought it. It came out of a manual truck though. According to Hollander, the rear shaft for MT and AT are the same, so now I have it. However, the intermediate shaft is longer, so I'll either have to keep looking or shorten the one I bought.
Also, according to Hollander, the Suburban that I'm picking up today to use as a parts buggy has a 2-piece driveshaft (which won't work), but does have a transmission with the bolt-on yoke. So I'm one step closer.
1988 R2500 Crew Cab
Future plans-
