Heater core help
I need help with replacing my heater core. I've never done it so any help would be great. I have a 68 without A/C. Any links or info/input would be great.
Re: Heater core help
Here's the FAQ on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=124556 Hope it helps. I tried looking at it all I seen for pics were little red x's. |
Active Member
![]() Join Date: Jul 2007
Do a search on heater core removal. Lots of good info.
The only problem you'll have is that one bolt at the bottom passenger side. Most guys just drop the wheel well. It's a bugger if you don't. And if you happen to be able to remove it without dropping the well, you'll probably not reinstall it... Here's the search I did: http://67-72chevytrucks.com/vboard/s...archid=1117253 |
i kno this guy that has done it to his sons chevy.. i dont know his screen name but i know of 88jrfan who is fixing rust and sees this guy on a normal basis you might search his name and ask him
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
