Old 03-05-2009, 11:30 PM   #1
americanmusc1e
americanmusc1e's Avatar
trans failing-6.0 swap or 700R4
Alright my TH350 started making death noises today and leaking fluid badly.
I have a 700R4 that i could get rebuilt and keep going, my smallblock is almost brand new (4000 miles) but I've been itching to do a 6.0 swap and i have a line on a 6.0 and tranny for around $1000 How many have done a 5.3 or 6.0 swap?? any opinions welcome
thanks
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-06-2009, 12:57 AM   #2
SactoJim
SactoJim's Avatar
Re: trans failing-6.0 swap or 700R4
That's a great deal for a 6.0 and tranny (many miles on it?). Should be a 4l80e behind that 6.0 if they came together originally, which makes for a stout package. I would think you would spend at least that for a quality 700r4 rebuild, but you may spend another grand getting the LSX swap to all work......but in my opinion worth it in the long run.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-07-2009, 01:28 AM   #3
americanmusc1e
yeah i'm seriously considering the swap but the truck is my daily driver and i don't know if i can do without it long enough for the swap
-- Josh
Old 03-07-2009, 07:10 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
I would pull the TH350 and spend ~$400 for a bench job at a tranny shop. it shouldn't take them more than 4 hours so you could have it done in a day or 2. then take my time on getting all the stuff needed for the LSx swap.
BTW, the 700R4 bench job will cost at least twice, maybe even tripple what a 350 does.
68C15 is offline   Reply With Quote
Old 03-07-2009, 08:49 PM   #5
americanmusc1e
anybody know anywhere to get a harness from besides painless????????
-- Josh
Old 03-07-2009, 09:11 PM   #6
boostat4500
If money is tight just get a stock harness, and modify it, not as hard as you may think. They can be found for $100-150 all day long. Then get a PCM that's has the needed stuff removed/added for another $100ish and a fuel pump for around $100 and your up and running. A set of motor mounts can be had for a $100 or less and your all set. This all assumes the motor is 100% complete with all accessories and manifold. Not as expensive of a swap as some will lead you to believe. You will need some different gauges depending on tranny etc. What all is included for that $1000?
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 03-08-2009, 02:13 PM   #7
americanmusc1e
please post build/swap threads that would be a great help to me
-- Josh
Old 03-08-2009, 02:33 PM   #8
dan42
dan42's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=251012
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-08-2009, 09:55 PM   #9
Andy4639
Old member
Andy4639's Avatar
As far as wiring.
Street & Performance is who I used. But when I did my TPI swap they were the only folks who did any of it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
