03-07-2009, 05:45 PM | #1 |
Seņor Member
Anyone work Lexan?
I'm looking to get some taillight lenses machined (see attached). The 3D aspect of them is meant to be a bit of post-modern '59 Caddy... that is, a pair of curvilinear arcs from the base to the top where they create a point... but along the whole length of the lens so that the 'point' is really an edge down the length of the lens. I've included a cross-section and end profile sketch in the attachment that may clarify. I'm looking for someone who can make me a pair of these, flame polish them, and then lay them up on a piece of prismatic clear that's bigger than the lens so they can be back loaded through the sheetmetal hole without falling through. I can provide more details to whomever might be able to make these for me.
Here's a shot of the truck now. Taillight lenses are in the slots now (backloaded as described above), but they're a flat surface. I need to add some dimension and character to them... hence the request. Anyone?
03-07-2009, 05:48 PM | #2 |
Seņor Member
Re: Anyone work Lexan?
A few better pics of what's in there now...
03-21-2009, 10:14 PM | #3 |
Seņor Member
CAD'd thanks to slammed67
No just need to find someone to cut it.
06-13-2009, 02:43 PM | #4 |
Seņor Member
New lenses are cut. But still need LOTS of sanding and polishing. Pics from my craptastic phone cam.
06-13-2009, 02:49 PM | #5 |
Cool. Who did ya' find to do them?
06-13-2009, 08:15 PM | #6 |
PROJECT 7DEUCE
Those are cool....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-27-2009, 05:09 PM | #7 |
Seņor Member
I wet sanded these today with 220 to get the tool marks off of them. Now to progress up to the 1000 grit range, then bust out the buffing wheel.
