Transfer case mount......
Does this mount look correct (the square tubing is not attached to the frame rail, and i'm not sure what it's doing there)? The mount attaches to the transmission correctly, but I don't see anything to help support the transfer case.
What concerns me is the angle from the trans to the t-case. Does anyone have a picture of the transfer case installed with the correct mounts? Truck is an 86, Np208, 350/700R4
2017 Tahoe Premier - Daily '99 Silverado 2500 Wife's whip- 2020 Equinox Premier |
Grease Monkey
Re: Transfer case mount......
Looks right to me. My brother has a 87 K5 with the same setup. I'll look and confirm the angle and I'll take a few pics.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
#3 | |
69 Chevy 4x4 383 Power ![]() Last edited by haysonj; 03-10-2009 at 09:21 AM. |
i have an 85, looks like the same POS corossmember, the angle is "to me" just what happens to them over time, and it also pulls the rubber mount in center apart in bending, loosens the bolts too over time. the sq i would say the PO wedged it in there to help prevent this from getting worse. (however it bends in middle not out the ends) the crossmeber is a weak design to me. wait to you hit something in the center of it offroading or get it hung on something it will bend it further down real easy. very weak, i'm replacing with an earlier type better crossection area. i'm assuming it is on the truck in avaitar...
