Old 03-08-2009, 10:16 AM   #1
jaros44sr
jaros44sr's Avatar
Need Help M/C demensions- Disc/Drum
I've read a thread on here where it was stated that the front chamber of the M/C is larger then the rear. It makes sense as the capacity would need to be more as the pads wear, and the bore is larger on the disc than the wheel cylinder. I don't doubt this, but my chambers are the same size.
When I bought the new M/C I held them side by side and everything looked the same, that does not mean that the PO didn't change it before me...so, my question is this, can someone verify the actual demension of the front chamber of a M/C with a disc/drum setup from a '72. I don't want to go back to the supply house without some sort of ammo.
Thank You for anyone taking the time to help me out...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-08-2009, 11:16 AM   #2
ratrod67
ratrod67's Avatar
Re: Need Help M/C demensions- Disc/Drum
Here's a couple quick pics. If you need something else let me know.
ratrod67 is offline   Reply With Quote
Old 03-08-2009, 01:05 PM   #3
jaros44sr
jaros44sr's Avatar
Wow, what a difference...as I suspected, the PO changed it to the wrong M/C. Thanks for the speedy response, now I have to take it apart and go back to the parts house
Thanks for taking the time
SAFETY FIRST
AS usual, off topic
Jim
Old 03-08-2009, 01:28 PM   #4
ratrod67
ratrod67's Avatar
No problem
Old 03-08-2009, 01:34 PM   #5
jaros44sr
jaros44sr's Avatar
Could I bother you for another demension? Center to center on the brake line holes, I'm concerned the new brake lines may be differant
SAFETY FIRST
AS usual, off topic
Jim
Old 03-08-2009, 02:32 PM   #6
ratrod67
ratrod67's Avatar
These ok?
Old 03-08-2009, 07:03 PM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
My disk/drum MC has different sized reservoirs as well. All disk/drums setups are like this now days.
texanidiot25 is offline   Reply With Quote
Old 03-08-2009, 07:41 PM   #8
texanidiot25
Eat My Rust
