03-08-2009, 02:28 PM | #1 |
cubic inches
Hi guys, just got a 1966 gmc pickup that was given to me. It's a straight 6. Don't know the cubic inch size. Can anybody tell me how to tell?
03-08-2009, 02:52 PM | #2 | |
Re: cubic inches
General rule of thumb is 230 & 250's had the 'small side covers' & 292's had the large side covers w/the larger valve cover.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-08-2009 at 02:59 PM. |
03-08-2009, 04:51 PM | #3 |
Re: cubic inches
Thanks Scott, that pretty much clears it up. I'll take the valve cover off then take the gasket down to local parts store. Thanks again.
03-09-2009, 12:06 AM | #4 |
60-66 Nut
Re: cubic inches
The 230's and 250's had the motor mounts straight across from each other. The 292 had the motor mounts slightly offset.
03-09-2009, 11:35 AM | #5 |
Its Deja Vu time again
Re: cubic inches
If I recall the side covers on a 230/250 are around 4-inches tall and the 292 is closer to 6-inches.
