Old 03-09-2009, 11:16 AM   #1
9teen69
9teen69's Avatar
Question Firewall plug to cover clutch hole?
Does anyone know where I can buy a plug for the firewall where the clutch linkage went through?
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 03-09-2009, 11:29 AM   #2
cdowns
cdowns's Avatar
Re: Firewall plug to cover clutch hole?
check a large hardware store
Old 03-09-2009, 11:39 AM   #3
fine69
fine69's Avatar
If you want an original good luck. The plug was made out of a grey plastic.
When it got too hot from the engine it warped and fell out.
That style plug was only made in 69 and 70.
71 and 72 had a bolt on cover. Very easy to find. If you dont need to be 100% correct you can find one easy.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-09-2009, 10:35 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I didn't know they used plastic though `70. That would explain why he has no screw holes...Thought they were all metal.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-09-2009, 12:04 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have a extra clutch rod delete plate. $13.00 plus USPS shipping. I can get pictures today after work. LMK if interested.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-09-2009, 02:13 PM   #6
C20_Paul
C20_Paul's Avatar
If you aren't bulding a show truck, you can head to the local hardware store and buy a 1/2 or 3/4 inch long bolt with a couple of washers large enough to cover hole. Then just tighten that sucker up.
If you are worried about moisture or fumes you could apply some silicon to the inside of both washers before the install.
I had several holes in my firewall on my 67 and I didn't want to just stuff them with plastic or rubber plugs. I am planning to pull my engine this summer and I will probably weld them all shut at that time, but this has been a great short term solution for me.
C20_Paul is offline   Reply With Quote
Old 03-09-2009, 02:56 PM   #7
9teen69
9teen69's Avatar
Thanks for the info, going by a wrecking yard tomorrow and I'll also check the hardware store - never thought to check.
my67chevytruck - I'll get back to you if I can't find.
thanks
Old 03-09-2009, 03:28 PM   #8
my67chevytruck
Under Construction
No problem. Let me know tomorrow if your interested or not. Finished up work early today. here is a pic so you know what they look like.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-10-2024, 10:04 PM   #9
NDM
I think I am going to remove mine an make a couple templates. I will then make copies with built in grommets for my LS swap. I might as well since I have one.
NDM is offline   Reply With Quote
Old 11-10-2024, 11:03 PM   #10
Classic Bowties
Always on the hunt...
NDM, am not sure if you caught that the original posting date of this thread was fifteen years ago or not, but as an FYI both styles of the firewall clutch rod delete block offs are now readily available with most of the truck part vendors, see post #4 of the below linked older parts board f/s thread. Mel
https://www.67-72chevytrucks.com/vbo....php?p=8986754
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 11-12-2024, 07:04 PM   #11
NDM
I did not know that thank you.
Old 03-15-2009, 11:28 AM   #12
9teen69
9teen69's Avatar
Rcvd part - thanks for the fast shipping!
Old 03-15-2009, 02:49 PM   #13
72armyswbtruck
72armyswbtruck's Avatar
I learned something new again.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
