Old 03-09-2009, 08:53 PM   #1
mole2000
mole2000's Avatar
parking brake strut
The mechanic told me that my parking brake strut is the incorrect one for my 1970 C10. Can anyone shed any light on whether that is correct info? I wouldve just prdered a couple of new ones, but havent found any yet.
He says it is too short and the groove is not wide enough... I'm measuring this one at about 7.5 inches.
Thanks for any advice.
mole2000 is offline   Reply With Quote
Old 03-09-2009, 09:38 PM   #2
463
463's Avatar
Re: parking brake strut
are you sure that you have the correct shoes and the drums have not been turned beond the max id stamped on the drum?
Trueman
463 is offline   Reply With Quote
Old 03-09-2009, 10:05 PM   #3
mole2000
mole2000's Avatar
the numbers I have say the drums should be discarded at 11.060 and mine are at 10.99 and 11.01. So they dont have another turning on them, but they are within spec.
As for the shoes I have to presume they are correct at this point. I will take a pic and compare to some found on the board.
The strut was too short before any parts were replaced and the e-brake was never hooked up.
Thanks.
Old 03-09-2009, 10:16 PM   #4
mole2000
mole2000's Avatar
i just had an light bulb go on in my head as I was looking at some board pics. Its too short due to the missing e-brake lever that goes behind the shoe is missing. they ordered that part and it will be in tomorrow. So hopefully it will work out.
Old 03-09-2009, 11:54 PM   #5
CTENTA1
Registered 1971 K5
I was going to say it looks just like mine and i have 12" drum. I also tried looking for those new one of mine was bent. Not so easy i tried all parts stores dealer even looking up under other applications. They say its a part that does not wear out so it does'nt need to be surviced. Good luck on that hope it all works out, i just ended up straightening mine cleaning and painting.
CTENTA1 is offline   Reply With Quote
