03-10-2009, 08:27 PM | #1 |
Grandpa in the rustmobile...
how do i tighten parking brake
okay,,,well i have NO parking brake....
crawled under there but didnt really see anything and wanted to go drive around, so i did lol....but how do u tighten it..like to get it working properly cause ive needed it a few times already..but i ditched tightening it and deicded to cruise around and take a few pics and have a chat with an older fella that had a 1960..some kinda mopar golden commander? i think thats right....it was REALLY nice...i stoped because he had a 68 gmc and a 71-72 swb lowered with big drag slicks on back that doesnt have a motor...i forgot to ask him if he'd sell it or part it out (for disc brakes lowering spindles) well heck for the swb maybe even! didnt get alot of pics of other peoples stuff but heres a few i took well i'll try to get pics later they dont wanna upload...lol how do i tighten my parking brake thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 03-10-2009 at 08:32 PM. |
03-10-2009, 08:40 PM | #2 |
Old member
Re: how do i tighten parking brake
When you crawl under the truck with the wheel chocked and brake off there is a all thread rod, I think it's on the drivers side it will have double nuts on it. Tighten them up to get all the slack out of the cable, but leave just enough so it's relaxed until you set the brakes. You may want some one to sit inside while you do this and try them every so often as you tighten the nuts up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-10-2009, 08:52 PM | #3 |
okie dokie thanks
what side of the Y is it on? thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-10-2009, 09:08 PM | #4 |
Old member
The rod should be right there on the drivers side under the floor inside the frame rail basicly. My 71 is anyway.
03-10-2009, 09:16 PM | #5 |
thannk you
03-10-2009, 09:21 PM | #6 |
have you taken the drums off to check the condition of brake shoe material if any// have you checked to see if the self adjuster star wheel is working properly?
03-10-2009, 09:27 PM | #7 |
im pretty stupid wen it comes to brake..but no i hanentt
03-10-2009, 09:33 PM | #8 |
Old member
You can't be stupid on something if you've never done it before.
Everybody has to start some place. If you haven't checked any of the stuff mentioned you need to. Either take it to a shop and get them to or have maybe a friend or someone you trust that knows mechanic's to look with you and show you what you need to look for. If you have a high school mech shop close by talk to the teacher and see if they will help you.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-10-2009 at 09:35 PM. |
03-10-2009, 09:39 PM | #9 |
ha im in high school
now, ive done fourwheeler drum brakes...i know there quite a bit the same..havent checked the brake shoes.. self adjuster starwheel....is that the lil thing u can adjust the brakes wtih or no..im fellin the answer isgonna be no lol
03-10-2009, 09:44 PM | #10 |
Old member
Yes that's the adjuster. Inspect the shoes just as you would your four wheeliers. If there is concern change them.
Now for the cable again. If you get under the truck and the cable is floppy loose then you need to tighten it up good. These old cables will stertch over 40 years. You may want to try a look in the F&Q section on brakes also.
03-10-2009, 09:46 PM | #11 |
its purty floppy lol
03-10-2009, 09:50 PM | #12 |
Old member
Tighten it up just enough to get the slack out. I like for my e-pedal to go about half way down.
As long as it holds the truck on a hill is good in nuetral.
03-10-2009, 11:19 PM | #13 |
Restoring it $200 at a time...
Start with your favorite rust dissolver product first. Those jam nuts are really easy to round off.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
03-11-2009, 03:28 AM | #14 |
Designated Grumpy Old Man
I assume that you have a 68. The manual states you should pull the brake handle out 4 clicks from the released position. Then tighten the adjuster on the cable until it is snug. This way when you release the e-brake handle the cable will relax enough to keep the brake shoes from dragging on the drums.
Good luck. PS. I would check the condition of your rear brakes first and then adjust the star wheel first before adjusting the parking brakes.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
03-11-2009, 09:40 AM | #15 |
Thats funny. When I had my truck inspected last year, the person said that it had to hold the truck still while in drive at 1500 rpms. Of course I'm in Texas, so that may just be a state thing.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
03-11-2009, 08:28 AM | #16 |
i second checking your brakes also
03-11-2009, 07:26 PM | #17 |
okay wat do i do if its tightened all the way up lol
03-11-2009, 07:33 PM | #18 |
Between Trucks...
You'll need a new cable if the old one's too stretched.
Beat it to fit, Paint it to match... |
03-11-2009, 07:43 PM | #19 |
dang...bout how much they gonna run
03-11-2009, 07:49 PM | #20 |
Between Trucks...
About $17 + shipping...
