Old 12-17-2002, 12:29 AM   #1
Hooter
My other Love
Hooter's Avatar
What would cause a power steering belt to go inside out?
i have been helping a friend work on his 1978 k20. It has a 350 and everyonce and once and a while his power steering belt will be in the same spot but it will be completely flipped. It is one of the wierdest things i have ever seen. Everything seems to be lined up. But it just disides to this everyonce and a while. anyone know what the heck is going on?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-17-2002, 01:51 AM   #2
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
I knew a guy with a caprice that did the same thing even with a new belt. Try a new belt, or adjust the tension. If that doesn't work, then you are were we ended up.
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 12-17-2002, 01:55 AM   #3
Hooter
My other Love
Hooter's Avatar
brand new belt and it been tightened, loosened you name it
pictures of my life
Old 12-17-2002, 04:25 AM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
bent pulley(s)??
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-17-2002, 09:11 AM   #5
BigRed
Sounds like either the pulleys are warped and/or aren't alligned correctly.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 12-17-2002, 10:38 PM   #6
swervin ervin
You get what you pay for
swervin ervin's Avatar
If the power steering pump pulley is not lined up right, it's rollover time. I know because when I first installed my headers and removed the AC, mine did the same thing. I had to use a spacer behind the bracket to make everything line up right. Lay a straight edge across the pulleys and check it. I bet the pump bracket is out of wack.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-18-2002, 02:32 AM   #7
J-Spec C10
J-Spec C10's Avatar
swerve: is there anything you don't know? You are the man!
Kyle
CANADIAN CONNECTION
Old 12-18-2002, 08:06 PM   #8
swervin ervin
Yeah lots I don't know, but I do a very good job of hiding it.
Mike
1985 Chevy C-10
Old 12-19-2002, 02:51 AM   #9
J-Spec C10
J-Spec C10's Avatar
swerve:
Ha! too funny! I know what you mean, other than online, I know the answer to the caramilk question...
Well, not realy but i'll do my best!
kyle
Kyle
CANADIAN CONNECTION
