Old 03-11-2009, 12:33 PM   #1
72c10lover16
72c10lover16's Avatar
Cutting Springs?
Anyone have any advice on cutting springs. I kinda was thinkin bout cuttin my springs to lower my truck. im on a very limited budget and i drive this truck everyday. Any feedback or opinions would be appreciated.
68 swb 4x4 327 4 speed
72c10lover16 is offline   Reply With Quote
Old 03-11-2009, 12:54 PM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Cutting Springs?
You can cut the fronts but you will have to replace or heat the rears.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-11-2009, 01:02 PM   #3
mr48chev
mr48chev's Avatar
As 72Freak said you can cut the fronts although the naysayers will tell you not to. It has been since people started lowering coil spring rigs and the biggest rub will be that the truck might ride a bit harsher. You should have the alignment redone after you do it though. I'd use a cutoff wheel rather than a torch.
On the rears you are going to have to change the coils to do it right. Heating the coil is the way a lot of guys used to do it but they usually keep sagging and there is a great chance that they will break at some time or another. There are also lowering blocks to get a couple if inches of drop but I think that they come close to the price of new coils.
Old 03-11-2009, 01:04 PM   #4
72c10lover16
why is it you cant cut the rears? just curious. i beleive you i am just wondering
Old 03-11-2009, 01:20 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
The rear coils are tapered on both ends. If you cut them you would have to have a way to re-bend them on the end. You can make some lowering blocks out of 2x2x 1/4" wall steel tubing but you would have to buy some new 2" longer "U" bolts. (about 30 bucks at a spring shop). I would not heat the springs...
LockDoc
Leon
Old 03-11-2009, 01:46 PM   #6
69halfton
69halfton's Avatar
when you cut the springs in front, how much more harsh is the ride? i would have thought that the spring would have been softer this way, and that the truck just bottoms out a lot easier?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-11-2009, 02:30 PM   #7
LockDoc
LockDoc's Avatar
Cutting one full coil off really shouldn't change the ride all that much. One full coil should give you a 2" to 2 1/2" drop. I don't think I would cut more than one coil though.
LockDoc
Leon
Old 03-22-2009, 02:07 AM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
I didnt think it was any harsher last time i did it
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-11-2009, 03:05 PM   #9
Brad
Out of the carpool lane.
Brad's Avatar
and don't use a torch, use a cutoff wheel instead.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-11-2009, 03:27 PM   #10
69chevybmx
69chevybmx's Avatar
I hate being the naysayer...
Springs are designed with a predetermined rate of travel and cutting them changes that rate. Springs designed for lowering are not just simply shorter, they also have increased rate to provide the ability to carry the load with the shortened amount of travel. IMO cutting springs to lower is like removing 1" from your shins instead of buying longer pants. it just doesn't seem like a good idea.
As for heating springs, you bring the possibility of continued spring sag AND it makes the metal more brittle and prone to snapping. You might save some cash by heating the springs but having one snap while doing 70+ mph would have been well worth the investment of proper springs.
When trying to save on money, your suspension is not always the best place to skimp.
69chevybmx is offline   Reply With Quote
Old 03-11-2009, 03:31 PM   #11
69chevybmx
69chevybmx's Avatar
Old 03-11-2009, 04:10 PM   #12
scrapmetalart
Junior Member
cut the fronts. The spring rate does go up a bit & it will ride rougher, but it is cheap. It is all in what you want to spend. 70's full size chevy cars have rear springs that will fit your truck & will lower it...
Heating them is a bad idea. They will break eventually...
I have used the torch to cut springs many times. only the very end gets hot...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 03-11-2009, 04:24 PM   #13
38chevyhotrod
38chevyhotrod's Avatar
I would not recommend it at all. I just replaced my springs, the fronts where cut and constantly made snapping noises when driving slowly in to holes.
The rears where heated to lower them, but they also didn't do it well.
After putting the lowering springs on the burb, it is driving much nicer.
It did cost 200 buck but it was well worth it.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 03-11-2009, 04:41 PM   #14
Skirkpat
Skirkpat's Avatar
Heating your springs is like letting all the air out of your tires, It will make your truck lower, but it is a really bad idea if you want to drive it.
Skirkpat is offline   Reply With Quote
Old 03-11-2009, 05:19 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
chopping and heating has been done for 50+ years. If done right, there won't be miuch of an issue.
It isn't the best way, but it works.
I would recomend chopping and cutting, (get someone who has done this before to help, otherwise some of the bad things could well happen) and never saying anything about it on here, many will shun you for it.
Old 03-11-2009, 05:36 PM   #16
lts70
1970 Daily Driver
lts70's Avatar
Cut them it works great and is not a safety issue if done right. I would not heat spring though as they seem to settle out over time and usually not evenly.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 03-11-2009, 05:41 PM   #17
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 03-11-2009, 05:49 PM   #18
69chevybmx
69chevybmx's Avatar
The odds of a brittle spring snapping and blowing out a tire causing the truck to careen out of control and burst into flames are slim to none. Fatalities (or accidents for that matter) caused by improperly lowered vehicles are probably about as common as lottery winners.
That being said, if there are players, somebody has to win.
Having a spring crack or sag though regardless of any safety risk is going to put you right back in the boat of needing a new spring anyway. You can always sell the OE springs to get back a few bucks.
Not here to shun anyone, my own father has cut the springs on every truck and hotrod he has built and never had a safety problem. They just ride like a hay wagon afterward.
Old 03-11-2009, 06:03 PM   #19
mexgrhd68
mexgrhd68's Avatar
1 coil=2in. lower stance, go from there. You might also want to trim your bump stop a little lower, to give that much more ride before it bottoms out.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 03-11-2009, 06:10 PM   #20
AlienYouth
AlienYouth's Avatar
i cut 2 coils, been ridin for a year like that, not so great for weight transfer at the track, but i would do it again if i get another truck for sure
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 03-11-2009, 07:26 PM   #21
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I'm just going to say that you don't want to go with more than 2 in of drop with springs,unless you are replacing the control arms.Most with more than 2 in of lowering in the springs have had alignment problems due to needing more shim to align than is safe.
This is even with factory lowering springs.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-12-2009, 01:33 PM   #22
texanidiot25
Eat My Rust
texanidiot25's Avatar
I've got 3in drop springs with no worried in the alignment department.
texanidiot25 is offline   Reply With Quote
Old 03-12-2009, 03:23 PM   #23
scrapmetalart
Junior Member
anyone cut 3" lowered springs to get another 1" or 2"?
Old 03-12-2009, 07:33 PM   #24
crazy longhorn
Fabricate till you "puke"
I havent tryed that......but lower than 3" on a spring, you are really pushin the limits of the geometry on the front end. I wouldnt do it.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-11-2009, 10:31 PM   #25
allen123
It'll buff out
allen123's Avatar
just to make it a little easier could someone post a picture of where to cut the spring?
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
