Old 03-11-2009, 03:35 PM   #1
Psycho71
Psycho71's Avatar
1-ton brake part question
Trying to find some parts to fix the brakes in the passenger side front wheel on a '68 1-ton. They all tried to escape and ended up in a tangled mangled mess in the drum.
Question is.....All the parts I find in the catalogs I have are for 3/4ton trucks. Will these work in a 1-ton too? I can't find these parts anywhere that are shown to be for a 1-ton.
Thanks,
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 03-11-2009, 03:42 PM   #2
Elephanthead
Re: 1-ton brake part question
I got every replaceable part from rock auto to do the front, the rear drums though are not available. Your going to have to do some filing on the wheel cylinder to get it to fit, but not a whole lot. Good thing is there are not a whole lot of parts. Bad thing is you have to buy both sides at once, but you probably need them.
Elephanthead is offline   Reply With Quote
