71chevytruckguy What A Weekend 03-12-2009, 01:01 PM
Wild83C10 Re: What A Weekend 03-12-2009, 08:37 PM
dammitmitchell Re: What A Weekend 03-12-2009, 11:51 PM
71chevytruckguy Re: What A Weekend 03-14-2009, 01:53 AM
Wild83C10 Re: What A Weekend 03-14-2009, 08:38 AM
dammitmitchell Re: What A Weekend 03-14-2009, 03:22 PM
71chevytruckguy Re: What A Weekend 03-15-2009, 02:21 AM
dammitmitchell Re: What A Weekend 03-15-2009, 07:01 PM
03-12-2009, 01:01 PM | #1 |
What A Weekend
Finally got the truck to the track this past weekend after a bustinmy tail to get it ready. Started out running 9.00s. After some timing adjustments and letting the clutch out at 4200rpm instead of 2500rpm got her down to a 8.478 @ 82.736mph with a 1.811 60'. Next pass slung the rear u-joint and figured since it was about 5:00pm on saturday and there was a free race on sunday, I could get parts and get it fixed. Unhooked the van from the trailer and headed to the nearest parts store, only 25 miles one way from the track. Got a new u-joint and u-joint straps. went to put the new straps in only to reliaze the the pinion yoke was messed up bad. So back to the van to drive another 30 miles one way to go to the house and get another yoke. Get back to the track about midnite. Put the new yoke one and go to hook the driveshaft back up on to see that the pinios is pointing up about 30 degrees. Yikes! Turned the spot welds that hold the axle tube in the diff had broke on the driver side caused all the load to be put on passenger side and twistin the tubes along with bending the trailing arm. So at about 1:30am decided to call it quits and go to sleep, and put it on the trailer and go home sunday. Bout the only good news was I found a buddy that had a good housing and welded the tube to the diff for $30 and I did learn a whole lot. Chris.
BTW, Its got a muncie m-20 it and I aint puttin an automatic in it. lol. I'd rather break parts left and right. lol.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
03-12-2009, 08:37 PM | #2 |
Re: What A Weekend
3 pedals is the only way to go.
Nice times and way to bust it to try and race again on Sunday.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-12-2009, 11:51 PM | #3 |
the pollock
Re: What A Weekend
bet you those cute lil imports behind you wre "sh** man look at that go"...
if they only knew what real HP was.. =-)
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
03-14-2009, 01:53 AM | #4 |
Re: What A Weekend
amen man. thanks. hopefully with some more tuning and some wieght reduction, i can get her in the high 7's. first points race is a week from satruday so i should have her ready by then. Chris.
03-14-2009, 08:38 AM | #5 |
Re: What A Weekend
Try and lose some weight and also work on transfering some to the rear. Some nice aluminum skinnies up front would help.
03-14-2009, 03:22 PM | #6 |
the pollock
Re: What A Weekend
pull your bench seat out and put a single seat in for the reace =-)
there's a few pounds..
03-15-2009, 02:21 AM | #7 | |
Re: What A Weekend
Not a bad idea but no money for another seat. I figure remove all the heater stuff, radio and speaker, carpet, passenger seat belt, extra bumper braces, and what ever else i can find. I cancelled the insurance and tags on it so I could go racing anything extra isnt needed. Chris.
03-15-2009, 07:01 PM | #8 |
the pollock
Re: What A Weekend
well a use single bucket can be had for like 40 bucks at a junk yard..
APC racing seats re around $160... dont weigh much... TAILGATE he he he buut if you strip out too much it'll loo like a junker dude.. and a custom dashboard can cur 20 or mroe pounds.. ALL un used wiring zipties and that factory thermal silencer mat can cut 35 pounds.. 100lbs = 1/10 of a seconds in a QM... but! i think it's alll worth it..
