Old 03-12-2009, 06:09 PM   #1
rddaves54
rddaves54's Avatar
lock ring exhaust bolts?
I am having a hard time finding these lock rings that went on the exhaust manifold blots. Has anyone found where these can be bought or a good replacement for them?
They came off my 72 Chevy Truck 350 V8 stock manifolds.
rddaves54 is offline   Reply With Quote
Old 03-12-2009, 06:19 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: lock ring exhaust bolts?
Make you some out of a S/S. Trace them out cut & drill. You can buy the small S/S sheets at LOWES.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-12-2009, 06:21 PM   #3
Wrenchbender Ret
Unless you want to be authentic you dont need them. Ive put hundreds of them on without them. I replace the bolts with grade 8 bolts & use the original thick washers or new grade 8 washers 7 tighten them down tight.
Wrenchbender Ret is offline   Reply With Quote
Old 03-12-2009, 06:29 PM   #4
leddzepp
Moderator
leddzepp's Avatar
You can get them at www.truckandcarshop.com
