Old 03-12-2009, 07:40 PM   #1
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Bolts/Nuts for motor stand & mounts
Can someone help me out...I need the correct bolts for the motor stand and mount for my SBC...What is the correct size bolt? Please excuse my ignorance
Clint
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 03-12-2009, 07:58 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Bolts/Nuts for motor stand & mounts
Mine were 3/8 by 16. ~1 1/4 inch long.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 03-12-2009, 11:42 PM   #3
truckintexas
You may already know this, but use only "Grade 8" bolts washers and nuts. They're made from hardened steel and can withstand a lot of force before they shear.
truckintexas is offline   Reply With Quote
Old 03-13-2009, 06:19 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can get the grade 8 bolts, nuts, and washers from your local Tractor Supply very cheap. They sell all grade 8 hardware by the pound in bulk.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-13-2009, 08:59 AM   #5
cdowns
cdowns's Avatar
grade 8 not really needed dont believe they came from factory// never had any problems with hardware store stainless
Old 03-13-2009, 11:16 AM   #6
b-rad
go grade 8 that is a lot of weight hanging out there on 4 bolts
b-rad is offline   Reply With Quote
Old 03-13-2009, 01:17 PM   #7
cdowns
cdowns's Avatar
just about zero wheight load on the motor stand bolts the whole load is gravity holding it down those bolts merely hold it in place and any torsional forces from the engine are disapeted thru the rubber in the motor mounts
Old 03-13-2009, 02:33 PM   #8
Robert8096
Robert8096's Avatar
If you are mounting the engine on a engine stand go with the grade 8 hardware. If you are talking about it sitting in the truck then stainless is the way to go.
Robert8096 is offline   Reply With Quote
Old 03-13-2009, 03:55 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
grade 8 is overkill
there's hardly any aplication on your truck that needs 8, grade 5 will do fine.
otherwise, sneakysnake is right, you have to measure the tube he circled on his photo.
Old 03-13-2009, 05:51 PM   #10
mbgmike
The oem's used grade 5 because thats the grade that it needed and it saved them money. For the cost differance (pennies) I would just buy grade 8
mbgmike is offline   Reply With Quote
