03-13-2009, 09:46 AM | #1 |
Mean Buzzin' Half Dozen
Cadillac Wheels.
Got a quick question for some of you guys. My 67 has the stock six lug setup, and the 2007 Cadillac wheels are six lug as well. Now from what I've read and found out the bolt patterns are the same, but will everything else work with what I have? Will the Cadillac wheels bolt on and tuck into the fender wells, will they fit over the hubs? My truck is a 2WD, lowered 3/4, and the rims are the 18" stock rims. Heres some info I found on the Cadillac rims.
S.No - 1 Year - 2007 Make - Cadillac Model - Escalade Bolt Pattern - 6x5.50in - 6x139.7mm Vehicle Offset - High OE Wheel Size - OE 18 & 22in Center Bore - 78 STUD Size - 14mmx1.5 Size Up - 23-26in Wheels Offset - 25-38mm Thanks, -D
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
03-13-2009, 11:38 AM | #2 |
Old member
Re: Cadillac Wheels.
I think they should fit the off sets maybe a little off those it will depend on the wheel it self though. All your new trucks went to 6 lugs. Tahoe's, GMC everything.
I like these myself. These are 20" wheels. I have them on my 07 Tahoe.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-13-2009, 02:08 PM | #3 |
Yeah those look nice, wouldn't mind getting my hands on a set of those either.
03-13-2009, 02:41 PM | #4 |
Newer chevy/GM 6 lug wheels do not work unless you machine the hub holes wider. It can be done though from what Ive read
1967custom |
03-13-2009, 03:57 PM | #5 |
its all about the +6 inches
and they'll be tucked in too far. The offset/backspace is way off. The front ones will probably rub way before the wheels turned all the way.
03-13-2009, 04:12 PM | #6 |
Okay, thanks for the info guys.
03-13-2009, 09:09 PM | #7 |
I think you can do it if you want
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
03-13-2009, 09:27 PM | #8 |
Eat My Rust
Rears will rub for sure, fronts you may get away with if you machine the hubs. I have a set of 17s off a newer GM truck, the front with machined hubs would've cleared pretty well at full lock, but the rears woulda needed 1.5in spacers
03-14-2009, 12:02 AM | #9 |
Ah well it's all said and done now. I just bought some wheels(not those) I'll have em' up for you guys to see eventually. I need to make a new build thread. I've done a lot....
