Hey guys i have an 83' GMC swb and i want to lower it but i dont know if i should go with a 4/6" drop or a 5/7" drop and what is the biggest i can go on wheels and tires without having them rub because later on i would like to buy some and about how much would the kit cost. It would be awesome if some of you guys could get back to me on this i would appreciate it alot. Thanks guys. oh and here are some pics of my truck if that helps
I have car A.D.D.
Re: Questions about lowering
I got everything together to drop mine 6/8 for under $500.
BAD BOW-Silverado XST
Nice truck. Do you plan to keep the current tire size for a while? Measure the distance between the fender lip and the top of the tire. Measure the front tire. The rear does not matter. The wheel is tucked under bed. Front tires have a wider travel path. 4/6 will leave a little gap with your current tires. The 5/7 will tuck the front tire nicely. Don't expect an exact drop. Coils and springs take time to settle.
Is your current tire size 255/60R15? Last edited by gchemist; 03-13-2009 at 01:41 PM. |
#5 | |
Some people plan a drop then realize their tires won't fit. If you plan to keep your current tires for a while, measure the gap between the front fender lip and the wheel. Use that measurment for as your drop guide.
I have car A.D.D.
I will get pics of it this weekend and post them up.
Cheyenne Super
I think the inner fenders are a little different on a 81 up, but my 77 had a
5 inch drop (front) and would rub 235/70s when it bottomed out on stock bumpstops. I would think 275/60s would rub too. 255/60s should be ok. |
do you think if i got new shocks also do you think it would help?
I have car A.D.D.
I made a post of my truck. Check it out and you will get an idea of the new stance.
6.0 powered square
I have 3" djm spindles and ground force spring's on my truck with less than 27" tall tires 215 70 15s there is a little more than a inch of gap parked with the inner fenders and when I turn sharp the inner fender sits on top of the tire
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Cruzzzn' Vet
This is my 83 with a 4/5 drop, 2 cut coils in the front and a flip kit in the rear, tires are 275/50/15's and 15x9 rims
Yea guys i think im going to stay with the same wheels and tires i have right now for awhile because bigger wheels and tires arent really in my budget right now. But a couple of days ago my dad told me that we where probably going to get the whole suspension redone on my truck
