Old 03-19-2009, 10:04 PM   #1
82Cecil
82Cecil's Avatar
Frame rivets wont come out
Slowly moving along with my lowering project.
I ground down the heads of the front spring hanger frame rivets on the rear leaf springs, thinking I could use an air punch and pop the sheared rivet through the hole.
NO GO.
The rivets seems to grab the cross section of the frame it passes through.
I am thinking now, progressively drill a larger hole through each rivet until I can easily colapse each one. My priority is preserving the integrity of the frame.
What is the best way to finish this job.
Thanks for your help.
82Cecil is offline   Reply With Quote
Old 03-19-2009, 10:06 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: Frame rivets wont come out
I take a die grinder and cut an X in the rivets head.....And the air chisel the remainder of the metal.....Seems to work most of the time........Hope this may help.....
bad6772 is offline   Reply With Quote
Old 03-19-2009, 10:25 PM   #3
bigblock73
yeller
bigblock73's Avatar
You aren't using a big enough hammer to punch them out, or you aren't swinging hard enough. I experienced the same thing on my 73...I just kept pounding. SOme came out real easy, others fought me.
bigblock73 is offline   Reply With Quote
Old 03-19-2009, 10:37 PM   #4
70k52wd
Blaze-Air
70k52wd's Avatar
I feel for ya. I have hand cramps from drilling. I had the same trouble, what you said is what I did. Drill, collapse...Good luck.
70k52wd is offline   Reply With Quote
Old 03-19-2009, 10:44 PM   #5
71swb4x4
71swb4x4's Avatar
This thread has some good ideas:
http://www.67-72chevytrucks.com/vboa...ghlight=rivets
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-20-2009, 12:22 AM   #6
Dark Knight
Dark Knight's Avatar
My method is to cut off the heads, heat it up cherry red with a torch, and use a center punch to knock them out. Works every time.
Dark Knight is offline   Reply With Quote
Old 03-20-2009, 07:17 AM   #7
silvereagle07
silvereagle07's Avatar
That's the same method I use.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-20-2009, 07:19 AM   #8
fast75
Go Hard or Go Home!
fast75's Avatar
i drilled mine, used a drift and a 3 pound shop hammer. be sure to use a center punch to aid in keeping center on the rivet. you don't want to elongate the holes if you can avoid it.
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 03-20-2009, 08:25 PM   #9
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Same here,No damage to the holes
powerdriver 1958 is offline   Reply With Quote
Old 03-20-2009, 11:28 PM   #10
budgetstperformance
budgetstperformance's Avatar
i removed the bumpstops for the rear and although the rivets are smaller than the spring hanger i believe my method would work for you. i cut the head off clean with the saw zall then ground it down with the angle grinder till i could see it was all the way through the head than cranked up the air compressor and pushed them out. you need a good airhammer with lots of psi and that saw zall was the best with some long fresh bimetal blades.
budgetstperformance is offline   Reply With Quote
Old 03-20-2009, 07:28 AM   #11
rick1956
rick1956's Avatar
Rivets are used in frames because of their ability to swell in a hole while still allowing for some movement (in a frame's case, twist) but grip securely and permanently at the same time.
I have spent quite a bit of time riveting airplanes together at a Boeing plant, and although I dealt with mainly aluminum, the effect and solution is the same.
The only real correct way to remove a rivet is to drill the center to almost the original hole size and punch the remainder out. At that point it will come out fairly easily because of the amount of metal that was removed allowed the remainder to give. If you can center-punch the rivet head to get it started, fine, but in many cases the head will be deceiving as to where the actual center of the rivet is. The best case for steel rivets is to grind the head off far enough to actually "see" the rivet shank and drill from there.
Don't use heat on a rivet--It will cause it to swell even further. The only way heat would be to your advantage is to heat the surrounding area, and you probably shouldn't do that.
Beating the hell out of them sometimes works, but at the expense of damaging panels. If you want everything to stay straight it's not advisable. You usually end up bending the piece of metal behind the one you're pounding on without seeing it.
Invest in a few new drill bits that are the correct size, and you'll be glad you did.
Hope this helps.
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 03-20-2009, 07:46 AM   #12
Cherub
Cherub's Avatar
For my flip kit I X'd the rivet head then ground off. Then did some gentle persuasion lol.
Cherub is offline   Reply With Quote
Old 03-20-2009, 10:44 AM   #13
nico
nico's Avatar
When I removed my bumpstops and did the spring hangers, I ground one rivet off and punched it out... After that, I found a good cold chisel and a better hammer... I had it down to a perfect rhythm, 21 hits with the hammer and the head snaps off, two more and the shank is gone.
nico is offline   Reply With Quote
Old 03-20-2009, 11:24 PM   #14
82Cecil
82Cecil's Avatar
Thanks everyone your generosity in repling to me.the rivets are out.
