![]() Join Date: Oct 2005
Trying to Minimize Bumpsteer
On my 72 I have an "old school" type drop on the front with stock spindles, stepped A arms, and drop springs. Downside to this (stock spindle) is I have too much bumpsteer for my liking.
Looking at it, it seems it would help quite a bit if I could flip the tie rod over on the spindle mounting point. I know that the spindle mounting hole and tie rod end stud are tapered and was wondering if anyone has ever messed around with this and had some "not too involved" success.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Re: Trying to Minimize Bumpsteer
I drilled mine out with a 9/16" drill bit; removing the taper completely. Then i replaced my stock type tie-rod ends, with heim joints with a 9/16" center bore. Worked perfectly.. just make sure you use a lock washer or a nylon nut with your bolt. I wouldnt suggest removing the taper from the spindle if you plan on keeping the stock tie-rod end.
Another comment.. You should NOT be experiencing any additional bump-steer unless you've changed your arm lengths, mounting positions, or steering mounts or lengths.. (just adding lowered a-arms and drop springs should NOT change your geometry) If you basic geometry is the same as stock (just lower) its not worse off than it was from the factory. Now I'm not saying that the factory setup doesn't have any bump steer, but its better off than some custom trucks driving down the road today.
I designed my suspensions from scratch, and i have 14 inches of front suspension travel, and less than 1/32" bump-steer through the entire arch of the suspension. |
#4 | |
Seems to me that the more perpendicular the tie rod is to the wheel, the less pronounced the change in toe will be as the suspension travels up and down. My tie rod angle is pretty dramatic when compared to the A arms and far from perpendicular. I only come to this conclusion by looking at it and visualizing what happens and also sketching it out in a CAD program. Ideally, I'd redo the front suspension, but I was just looking for a quick fix....or semi fix.
Fabricate till you "puke"
Yea, your bump steer is due to the angles on the tie rods. You can get by with about 3" on a spring.....but add the dropped arm to the mix & the trouble starts. I saw a kit (DJM suspension IIRC), that drills the spindle, taps & installs an insert(with locktite) to flip the tierod over the top side of the spindle. This should correct the bumpsteer issues, & retain the stock pcs. I havent tryed it , but looks like it should work to me
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#6 | |
![]() Join Date: Apr 2004
i had the same suspension on my blazer before I bagged it. It also had bumpsteer. If you don't want to bag it I would suggest stock arms with drop spindles and lowered coils.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
