2wd to 4wd?
how much of a disaster project is putting 4wd into my truck? are they even the same frame? guy has the trans, t case, axles, springs, and wheels not sure on driveshafts but probably. his is a 3/4 long bed too. i really just need a rear spring pack(is that the same 2wd to 4wd?) but if i can make it 4 wheel then hey why not.
http://i16.photobucket.com/albums/b3...fleet041-1.jpg 71 custom camper/20:292/saginaw, my first pickup ![]() 83 cutlass cruiser:307/th250c, lifelong project 96 caprice 9C1:LT1/4L60E, police package 83 buick regal estate: buick 350/m20 69 bel air:250/m21 |
Re: 2wd to 4wd?
There was a thread on this a while back and if I recall the verdict was find a 4WD frame, otherwise it's too much of a PITA.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Bloodied Knuckles
Re: 2wd to 4wd?
Sounds like an abortion to me, You'll be making custom cross-members, depending on your skill level, it maybe better to just find a new frame or a rolling chassis, plus you can do a frame up build :P would love to see it. 2 wheel drive and 4wd use different rear springs, i believe 4 vs 5 spring, possibly different lengths but I honestly dont know.
Re: 2wd to 4wd?
mines a 6 spring rear, probably due to the custom camper package. LMC and such dont list 2wd rear leaf springs, just 4wd. i keep meaning to call my local spring shop, i'm sure they can make a spring for it but i'm trying to go as cheap as possible to get it inspectable. screw the 4wd for now, i dont need another big project just want my pickemup back on the road, i have junk to haul!
Re: 2wd to 4wd?
from my build it was easy just drilled 4 holes for the t case and everything swapped easy but i have a custom camper
o, leafs are the same well i used the same axle for the back
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 03-21-2009 at 08:17 PM. |
Re: 2wd to 4wd?
Sounds like people haven't converted a 2wd frame to 4wd.
I have. I'd say it's easier than a body swap. Check my sig. Last edited by FormerMember; 04-02-2009 at 03:23 PM. |
#7 | |
![]() Join Date: Apr 2009
Re: 2wd to 4wd?
Re: 2wd to 4wd?
i know body swaps can be hard lining it up with the frame front clip and the bed
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
Re: 2wd to 4wd?
i talked to the guy a bit today, its a rolling chassis for $500 so i'll probably get it sometime next month, need to get rid of some stuff first. i guess someone used the cab and bed on a 1/2 ton project, not sure how long the frame has sat around but i'll check it out next weekend most likely.
