Old 03-21-2009, 09:21 PM   #1
JW76
JW76's Avatar
rear disc conversion
I have an 86 c10 with power disc brakes in the front and drum in the rear. I would like to convert the rears to disc. Do you need to change the master or just the proportioning valve when you do this? Thanks for any help.
JW76 is offline   Reply With Quote
Old 03-21-2009, 09:26 PM   #2
JW76
JW76's Avatar
Re: rear disc conversion
I forgot to add that I have a really lumpy cam in the motor. The lsa is about 110 degrees, so the brakes are a little sluggish due to the lack of vacuum as is.
Old 03-21-2009, 11:37 PM   #3
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
any one
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 03-22-2009, 12:05 PM   #4
JW76
JW76's Avatar
Been reading some of the old threads. Can you use the front stock truck rotors with the 5x5 pattern on the back and use a mid 80's camaro caliper and buy or fab the mounting brackets?
Old 03-22-2009, 12:21 PM   #5
blackdiesel
blackdiesel's Avatar
If better brakes is what your looking for, the rear disc won't fix it. An ele. vac. pump would though.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-22-2009, 12:28 PM   #6
JW76
JW76's Avatar
i have a vacuum pump i can install... but i was looking to do 4 wheel disc and solve the vacuum problem also... if that would work
Old 03-22-2009, 08:23 PM   #7
tvblazer78
Low & Fast!
tvblazer78's Avatar
You need to change both so you will have a Disc to Disc master and valve
tvblazer78 is offline   Reply With Quote
