steering wheel install help
Hi All,
I need some help installing a steering wheel (1970, 3/4 ton, no tilt). I took the old steering wheel off (looks like from a later model, whoever installed it had to cut the back of it off to get it to fit). With the steering wheel off, I have the turn signal cam. I have nothing else between the tun signal cam and the back of the steering wheel. Looking at the LMC catalog it looks like I need a few more parts (spring & plastic housing). Does anyone know the order of installation and if I will need any other parts? I did bolt the steering wheel on and it had about 1/2 inch of vertical play in it. Will installation of the remaining parts take this play out? The steering wheel I have is out of a mid 70's truck so maybe this is causing some of the play as well. I am not going to mess with the horn button stuff right now (I have the horn disconnected). Thanks for any help. |
Restoration Virgin!
Re: steering wheel install help
check this thread out....http://67-72chevytrucks.com/vboard/s...d.php?t=258402
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
The Older Generation
Here are a couple more. http://67-72chevytrucks.com/vboard/s....php?p=3085732 http://67-72chevytrucks.com/vboard/s...ad.php?t=79039 http://67-72chevytrucks.com/vboard/s....php?p=2995598 LockDoc
Thanks for the references. Does the LMC catalog have the correct parts in the correct order? Does the spring fit between the bearing and the plastic housing (item #11 in catalog)?
Thanks again. |
Restoration Virgin!
Look at that thread I sent you....they talk about that....from what they say, I don't think it is shown in the correct order
