03-25-2009, 03:58 PM | #1 |
Patch Panel ?
I am having a little trouble finding out how far this pillar patch comes down in comparison to the brace in the pic. Do these holes line up exactly? I know some of you guys have done this allready. Any help is much appreciated.
03-25-2009, 10:52 PM | #2 |
Re: Patch Panel ?
I am just finishing mine, I recommend you buy the part that welds to the pillar patch contact wes at heartbeat hes only one i know of who has it , in regards to holes lining up in repair panels to origanal I have no luck doing it that way so far but its not completed either so we shall see
03-26-2009, 03:12 PM | #3 | |
Re: Patch Panel ?
03-27-2009, 06:54 AM | #4 |
Re: Patch Panel ?
Picture help any?
[IMG][/IMG] How can I measure this best to help ya out? Sorry: Have the pic for you but the board isn't allowing anything right now, I'll check back and post it later. Last edited by vtblazer; 03-28-2009 at 12:05 PM. |
03-28-2009, 10:35 AM | #5 |
Re: Patch Panel ?
VT- I was thinking of using the top bolt for the rocker box support as a reference point. I will try to post a pic. Thanks for your help.
03-28-2009, 11:22 AM | #6 |
Not a bad nut after all..
Re: Patch Panel ?
Subscribed!
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
03-28-2009, 02:29 PM | #7 |
Rods
Re: Patch Panel ?
your local nut and bolt should have the square nuts they are cheeep. as for the referance I went to home depot and bought a tool that wood workers use to find molding shapes. just use the outside bed panel for referance transfer that to paper.
03-28-2009, 05:08 PM | #8 |
Re: Patch Panel ?
I think there may be some confusion. I am installing a new lower b-pillar extention. This area was completly rusted away so I was looking for a reference point to get me close to where the original was. I thought someone could measure from the top bolt down to the bottom of the pillar extention. The only problem is you would almost have to be in the middle of this repair to provide this info.If the floor is already in place,this measurement could be taken from the bolt to the floor and then from the floor to the bottom of the pillar extention. Sorry for the confusion and thanks again for any help!
03-28-2009, 09:27 PM | #9 |
Re: Patch Panel ?
I would use the body crease on the lower fender as a reference, this will set the elevation
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-28-2009 at 09:56 PM. |
