Old 03-26-2009, 05:13 PM   #1
Rain City
Question Won't Idle until warm
Hello - I have a 81 c10 with a 350 that was dropped 30K ago
One thing that I am having trouble with that the car will not idle until it warms up. I have to rev it a little bit for a few minutes before it will idle... we're talking Seattle weather too around 30-50 degrees lately.
Is this normal?
Rain City is offline   Reply With Quote
Old 03-26-2009, 05:48 PM   #2
low&slow
Re: Won't Idle until warm
i live in idaho and im having the same problem..im not an expert on this but its warm out right now were i live and i don't have to rev it..i believe its just the cold cause the cold makes your block cold..if that makes any sense to you at all
low&slow is offline   Reply With Quote
Old 03-26-2009, 06:03 PM   #3
redrat
gearhead
redrat's Avatar
it sounds like your choke is not working.. What kind of carburetor do you have? it probably has an electric choke? it may just need adjustment. Let us know what ya have and we can tell you how to adjust it.
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 03-26-2009, 06:08 PM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
check your choke and make sure it's still working well =-)
and well that's pretty typical
p.s. good lookin truck
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-26-2009, 06:21 PM   #5
Rain City
Thumbs up Re: Won't Idle until warm
To tell you the truth I don't know if it has a choke?
It's got a holley carb in it... here's some pics...
thanks for the quick responses!
Old 03-26-2009, 07:13 PM   #6
dga93
newbie
dga93's Avatar
I'm in VA and have the original 350 in my 78 and mine doesnt like to either.
dga93 is offline   Reply With Quote
Old 03-27-2009, 11:12 AM   #7
Rain City
Any help would be appreciated!!
Old 03-27-2009, 11:27 AM   #8
tvblazer78
Low & Fast!
tvblazer78's Avatar
Take your air cleaner off and see what the choke dose when you pull it out, it should close off the front two openings. Take a pic and post it.
tvblazer78 is offline   Reply With Quote
Old 03-27-2009, 11:55 AM   #9
454HO
Looks like it may be a manual choke, and it is just jury rigged. If so you need a cable so you can operate it manually in the cab.
Also looks like your throttle return spring is stretched waay too far and you have one of those cheap glass fuel filters. Both are not good.
- Greg
454HO is offline   Reply With Quote
Old 03-27-2009, 11:58 AM   #10
morcey2
I picked up an 84 that had the same problem. Choke linkage was jacked up holding the choke open all the time. I fixed it and it starts right up on days where we were well below freezing and close to 0.
If that spring going from the throttle linkage to the front of the engine is your throttle return spring, you need to get it setup right and get a dual spring. It looks like it's going the wrong direction also. Not sure what that setup is. The electrical tape wrapped around the linkage by the vacuum secondary diaphragm also has me concerned. I don't know tons about holley carbs, but I'm pretty sure that's not a standard setup by any stretch of the imagination.
Matt
morcey2 is offline   Reply With Quote
Old 03-27-2009, 12:06 PM   #11
LONGHAIR
That rod/electrical tape mess is holding the choke totally off. It is a manual choke that just needs a cable installed to work properly. When the choke is working, you should not have to fiddle with the throttle to get it to idle.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-27-2009, 01:09 PM   #12
tvblazer78
Low & Fast!
tvblazer78's Avatar
You are right, I just looked back at the pics and it not hooked up at all, just wide open. Good eye longhair...
Old 03-27-2009, 01:44 PM   #13
Rain City
Lightbulb Re: Won't Idle until warm
Wow you guys really know what you're talking about. I took off the air filter and 'crappy tape rod' and it looks like this
So... I need a choke cable (and housing?) My autoparts store should have this, yes?
In terms of hooking it up..Are one of these a choke handle/puller?
I would assume that it needs to go through my firewall... would it go through something here?
I am a super n00b and this is my first real 'running project', asside from my motorcycle/motored bike projects... so thanks for the help so far
Old 03-27-2009, 01:59 PM   #14
swb85
On a budget like Fred Sanford
swb85's Avatar
Your local parts house should have a choke cable kit in the HELP section. You can run the cable through the grommet on your firewall by the distributor that all those wires are running through. Try to make smooth turns (avoid kinking it) when routing the cable into the cab to ensure smooth actuation. Here's a pic of where I mounted my choke cable, you can see it on the bottom of the dash right above the shifter.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 03-27-2009, 03:34 PM   #15
88 Dippy
88 Dippy's Avatar
nope that is to allow outside air into the cab when it is pulled out
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 03-27-2009, 03:33 PM   #16
Rain City
OK! I got it, went to the auto store and got the cable. Just installed it, and can't wait to put it to the test.
I've only had this truck for about a month now, and I'm learning new things about it everyday - for better or worse haha.
THANKS GUYS!!
