03-26-2009, 06:27 PM | #1 |
annoying rivets
can anyone tell me the easiest way to get these annoying rivets off that hold everything to the frame?
03-26-2009, 06:50 PM | #2 |
67-72 parts collector,…
Re: annoying rivets
Cut an "X" in the head with a grinder (equipped with a cut-off wheel).
Then take a chisel or air chisel and knock off the head. Take a punch and push the remaining rivet through the hole.
03-26-2009, 07:04 PM | #3 |
Re: annoying rivets
x2
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
03-26-2009, 07:52 PM | #4 |
Re: annoying rivets
ill give that a try thanks for the help
03-26-2009, 09:24 PM | #5 |
Happy to be here
Re: annoying rivets
While it might seem like a good idea, don't use this-
03-26-2009, 11:58 PM | #6 |
Re: annoying rivets
That's nice candle you got there! Will it keep the bugs away from your patio?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
03-27-2009, 04:13 AM | #7 |
Re: annoying rivets
Ive always had the best luck w/ a good air hammer and and a chisel tip. Of course this is assuming you have a air compressor.
03-27-2009, 06:41 AM | #8 |
Re: annoying rivets
grind the head flush first the heat from thr grinder will help "loosen the rivet up then take a pointed air hammer and knock it out. This works has always worked well for me
03-27-2009, 08:47 AM | #9 |
Re: annoying rivets
thats what i have been doing but using a grinder seems to just scar up the frame around the hole and it doesnt always work for me
03-27-2009, 08:48 AM | #10 |
Re: annoying rivets
and the dynamite has crossed my mind several times
03-27-2009, 02:39 PM | #11 |
Re: annoying rivets
Any ideas on how to remove the rivets that hold on the rear suspension bump stops on a 64 frame. I dont have an air chisel and there is not enough room to fit a cut off wheel to cut down the heads.
Tommy~ The difference between genius and stupidity is that genius has its limits -- Albert Einstein 63 build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=317341 |
03-27-2009, 02:58 PM | #12 |
Re: annoying rivets
I just removed some yesterday on some trailing arm brackets I didn't have my air hammer so I ground the heads flush then drilled 1/4" holes in the center of the rivet just deep enough to enough to get past the bracket that way I was able to hammer them out with little effort the hole gives the rivet room to contract.
