Old 12-20-2002, 04:20 PM   #1
Scorpion
Rear axles
I have a 1970 GMC Long Bed with a SBC 327. The front end has been converted to five axles and disc brakes. I dont really care about rear disc but I would like to install the 5 bolt axles. How can this be accomplished and what parts are needed. I am new to the forum so please be easy on me. The rear is a Chevy 12 bolt. Thanks
Tony Wagner
Scorpion
Fasttimez Racing
Scorpion is offline   Reply With Quote
Old 12-20-2002, 05:06 PM   #2
crazy longhorn
Fabricate till you "puke"
Welcome to the "madness"! the 70 12 bolt should accept the 71-72 axles......also i beleive the 73 up axles will fit. 67-69 the housings were about 1 1/2" narrower, so they would require an aftermarket axle. Good luck....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
