rear cross sill fleetside
is the rear cross sill bolted up with the 4 bolts on each side or do you only use the ones where you can get the nut and bolt threw , also was it ever tack welded in place. thanks
Re: rear cross sill fleetside
The rear cross sill on the '60-'66 fleetside beds have four bolts on each end and two tack welds holding them in place. There was a thread within the last week or so about this topic that may be helpful, also.
60-66 Nut
The ones I've seen had not only the two welds on the top, but were also welded vertically on the back.....towards the tailgate.
I just pulled mine apart and Lilred is correct about the bolts but at least on mine there was more than just a tack weld holding things together. There is a horizontal weld that is pretty easy to get at but the vertical weld can be a little trickyer. I ended up using a combination of a grinder/cut-off wheel and a small compact type hacksaw. Just take your time and you will be all good.
Tommy~ The difference between genius and stupidity is that genius has its limits -- Albert Einstein 63 build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=317341 |
283 Drama Queen
![]() Join Date: Dec 2004
![]() Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
i replaced mine already , i just didn't weld or bolt it up yet , i just wanted to see how every body's cross sill was , thanks
