03-31-2009, 10:33 PM | #1 |
6 lug to 5 lug rear
Hi everyone I have a 86 c10 and i have a 86 12 bolt posi laying around but it has the 6 lug bolt patter. I have a 10 bolt non-posi under the truck right now, what is involved on maiking the rear end a 5 lug? Can I just swap the axles out? Or is it more complicated than that? Thanks!
1986 Chevy C-10 2WD Long Box 406 SBC 12.5/1 compression E-85 monster! |
04-04-2009, 11:24 AM | #2 |
Re: 6 lug to 5 lug rear
ttt
04-04-2009, 11:34 PM | #3 |
if you can find a 5 lug 12 bolt at the junk yard the axle will bolt right in where the 6 lugs are. you will nead the drums for the 5 lug brakes and make sure the drum diamiter is the same
04-05-2009, 12:02 AM | #4 |
BAD BOW-Silverado XST
As far as I know, you can swap the axels. 12 bolts were available to 82.
04-05-2009, 01:03 AM | #5 |
Jonny
Ok, here's what I've heard. Swapping 5 lug axles into a 6 lug axle won't work, I think because of the length of the axle, but this is messing with a 60-72 12 bolt. The 73+ may be different. However I've been told that you can swap the carriers around.
Now, what I would do is grab a complete 5 lug axle and figure out which parts to mix and match.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
04-05-2009, 04:17 AM | #6 |
Any 8.5" 10 bolt or 12 bolt have interchangeble axels. Including the back plates for the brakes. The pinion and ring won't interchange. Same for a posi or gov-lock.
04-05-2009, 04:22 AM | #7 |
The axel shaft interchangebility is for any 10 or 12 bolt after '70. Older models won't interchange like sailed2japan states.
04-05-2009, 08:34 AM | #8 |
Is it possible to just change the front brake rotors to six lug using the existing brake caliper?
I see sets of OEM six lug 16" GM alum wheels on CL going cheap.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck 1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac |
04-05-2009, 12:44 PM | #9 |
Jonny
I was reading on the 67-72 board that someone makes a specialty rotor that works with the hevy duty 1/2 brakes to convert to 6 lug. It only works if you have the 1.25" rotors, though.
04-05-2009, 11:15 PM | #10 |
be carefull there is a truck 12 bolt and a car 12 bolt and they are different.
04-06-2009, 09:25 AM | #11 |
Jonny
Yes, definately, but I haven't figured out which one is in an El Camino....j/k
