![]() Join Date: Dec 2007
Gas gauge help
I recently got my gas guage hooked up in my 72 chevy stock tank behind the seat. When i turn the key it always goes up to about 3/4 tank and stays there, even when its basically empty. What could be the problem?
![]() Join Date: Feb 2004
Re: Gas gauge help
Might be a stuck float in the tank.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Re: Gas gauge help
Whats the best way to get it unstuck
454 MAKES IT ROAR
Re: Gas gauge help
You will have to remove the float from the tank to see if it's the prob, but it could also be the resistor prob these are found on the back of your gauge, also check the Brown earth wire from tank to F/B.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Gas gauge help
before you take the sender and float out of the tank, remove the tan wire from the sender and see what reading you get. It should go past full. Then ground the tan wire on the side of the sender or any good ground and the needle should move to the left past empty. If these things happen then the problem is in the sending unit or float.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
