Old 12-22-2002, 12:16 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Pinion nut torque spec?
How many ft. lbs. should i torque the pinion nut on my coil spring 12-bolt rearend? I can't seem to find it in any of my manuals. Or is the torque spec different for each rearend?
Thanks for any help.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-22-2002, 12:25 PM   #2
crazy longhorn
Fabricate till you "puke"
There is no tork spec per say on the pinion nut on a 12 bolt. With the carrier & ring out, the pinion nut should be tightened enough to crush the sleeve, & give about 8-10 inch lbs rotating tork on the pinion(used bearings , & oiled). if you have new bearings, the figure is a little higher(about 12-15 inch lbs). The books will show a higher figure for new bearings.......but the driveline shops will run them a little looser to prevent "blue bearings". good luck.....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
