Old 04-06-2009, 09:59 AM   #1
chevyrestoguy
chevyrestoguy's Avatar
Brake differences, 73-80, 81-87
I checked the Search function, and didn't get the answers I was looking for, so I decided to post a question:
Heres the scenario- I got a great deal on a new pair of Bell-Tech 3" drop spindles that were thought to be for an 81-87, but I discovered that they were for a 73-80 (Bell Tech part # 3100) with the 1.25" rotors. I have an '83 with the 1.0" rotors. To convert to 1.25 rotors, I'm figuring that I'm going to need to get rotors, the proper 73-80 calipers and bearings. Anything else I'm missing?
The original 1.0" rotors were past their minimum thickness, so I was going to need to replace them anyway. The original calipers looked like they needed to be rebuilt, so no big deal there either. I might as well change out the brake hoses while I'm at it. I was planning to completely go though the brakes and also do a rear disc conversion, so this is a good excuse to put a better brake on the front. I was never too crazy about the thinner rotors anyway. Our trucks are heavy, and they need all the stopping power they can get.
chevyrestoguy is offline   Reply With Quote
Old 04-06-2009, 10:23 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Brake differences, 73-80, 81-87
the parts you mentioned, but you also might need a larger brake booster, and master cylinder
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=158
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-06-2009, 11:20 AM   #3
JohnC
JohnC's Avatar
I am doing the same thing, and from what I have been told the spindle will have to be changed as well, unless you are going with an aftermarket one anyway.
JohnC is offline   Reply With Quote
