04-06-2009, 09:36 PM | #1 |
hei issue
Anyone else run into this problem, just dropped in a 65k hei from Skip White, the vacum advance hits the manifold and blocks the manifold vacum port, Im hoping that once I get it wired up and timed that the correct timing postion will take the vac adv far enough clockwise to get it out of the way, anyone else have an issue with this
04-06-2009, 10:11 PM | #2 |
Re: hei issue
Yea thats how it was for me too, i just put an elbow on it and pointed it the other way, i used a fuel line to attach to the elbow to give something for the hose to go over. Here is the elbow i used, although its not pointed that way anymore. i have it pointed to the drivers side.
04-06-2009, 10:29 PM | #3 |
blood type; Retumbo
Re: hei issue
why is the vacuum can off by almost 1/4 turn? I would stick with a good GM HEI.
04-06-2009, 10:37 PM | #4 |
Re: hei issue
Can't you just move the plug wires all over one hole and then move the whole distributer back some?
1968 Chevy - 292 with a powerglide |
04-06-2009, 10:37 PM | #5 | |
Sierra Grande Club
Re: hei issue
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
04-06-2009, 10:42 PM | #6 |
laying low
Re: hei issue
Yes. As far as where the vacumn can is located it is just a matter of pulling the dist out, turning the oil pump shaft clockwise just a bit and reinstalling the dist with the can turned more to the rear. No need to move plug wires that way.
04-07-2009, 07:36 AM | #7 |
Re: hei issue
wouldnt you have to move the oil pump and the plugs, cause if you took it out at #1 tdc then move turned the oil pump and put it back in, the rotor will be pointed at a different plug
04-07-2009, 07:59 AM | #8 |
Re: hei issue
Sounds like you are off one tooth on the cam with the dist.
72 chevy 3/4 ton 4X4 |
04-07-2009, 10:30 AM | #9 | |
laying low
Re: hei issue
Also, it may be easier for some to just move the plug wires around 1 terminal on the dist cap then readjust the timing.
04-07-2009, 08:53 AM | #10 |
Re: hei issue
Mine is pointed just like the one in the pic. you should be able to get it close to see where it will sit before cranking it. if its not pointing the right way you are off a tooth.
