Old 04-07-2009, 08:50 AM   #1
DZL1
One day.....
DZL1's Avatar
Question about oil pan
Is it possible to remove pan without lifting motor? Thanks.
DZL1.
DZL1 is offline   Reply With Quote
Old 04-07-2009, 09:41 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Question about oil pan
No. The motor only has to go up enough to put some pieces of 2 x 4 between the motor mounts and stands.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-07-2009, 09:51 AM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Depends - I can remove stock or aftermarket oil pans off my Big block without jacking up the engine
You may have to spin the crank to get the crank arms on the front of the crank out of the way so you can clear them and pull the pan towards the back
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 04-07-2009, 10:14 AM   #4
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
the key way on the crank needs to be pointing to 6oclock
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 04-07-2009, 08:53 PM   #5
DZL1
One day.....
DZL1's Avatar
Thanks for all the input guys.
DZL1.
