anything i need to know about a automatic swap??(4x4)
hey, on my 67 it is now a 292 3 on the tree deal, coming real soon im pulling the engine, trans, transfercase, and column. i have everything i need for the swap. im putting in a 383 stroker, th350 and a np205 transfercase. will the bolts and everthing bolt up from the old tranny and transfercase? or will i have to end up drilling stuff. also im putting in a tilt column
![]() matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
The top parts off the frame for the engine mounts need to be changed,,... the 292 mounts are in different locations than necessary for the V8. The rockwell transfer case which is probably in your truck now will use u-joint type connections for the drive shafts... depending on the year your np205 is from you may have a need for different type mounts for affixing the drive shafts to the transfer case. If the NP is from between 70-75 you should be OK.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Check the 4x4 board. This has been discussed there at least a couple of times.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
i have a V8 crossmember, and the transfercase is out of a 72 gmc burb.
