Sierra Grande Club
HEI wires
I need to hook up my HEI and can't find the diagram for the wire connections.
I have only one wire to connect from the engine harness but there are 3 on the skip white unit- RED BLACK and YELLOW. Anyone know what the wires do? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Too Dumb To Know Better
Re: HEI wires
Are those the wires that plug into the cap?
Sierra Grande Club
Re: HEI wires
No, they come out of the bottom of the dizzy. I didn't even look at the cap real close. I know it has the coil but you have me thinking....
s/t
its all about the +6 inches
Re: HEI wires
it plugs into the cap, right behind the coil/tach plugs
Sierra Grande Club
Man to I feel stupid
![]() ![]() I ordered the dizzy back in February 08 and haven't touched it since. Thanks for the clarification. s/t
Re: HEI wires
you will also need a 12v supply from the battery to the terminal that is right in front of that plug, look at the top of the cap ( plastic cover ) and it should be marked tach / battery. Have to do this or you will not get power to the coil so it will fire and run
