66 Pickup original gas tank: pros and cons
When I was in the military deploying every year I always had problems with a car garage/business taking advantage of my wife when the car broke. Finally I found this older gent, mid 60's in age, named Cecil, near NAS JRB Ft Worth, TX, who owns and operates his own garage. My wife and I trust Cecil completely so If anyone needs an honest gent to work on their vehicle, contact C&C Auto Service near Lake Worth. Cecil is not in the greatest of health, cancer in remission, go see him, he will treat you like you've wished a garage would treat you!
So I was talking to Cecil the other day about putting in the original gas tank in my 66 Chevy. He said, "That tank worked fine in the day, ......son the only issue was the rubber portion on the gas filler neck would dry out and allow vapors to enter the cab. Change the rubber out every 7-10 years and keep on runnin." What's everyone's opinion here. I like the look of the gas cap on the cab....is everyone using it or is it decorative and running an under the bed tank? What's the pros and cons please. thanks ![]() |
Daring to be Different
Re: 66 Pickup original gas tank: pros and cons
This is a great topic. Personally I don't like the tank in the same place passengers are. If you put a tank under the bed you loose the spare tire space. I think it's worth it though. There is also tanks that fit in the bed. I think those are the only options you have.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
The biggest advantage of removing the tank from the cab is space. Space for a sound system, storage, etc. Some will say safety, but how many incidents of these original tanks blowing have you heard of. My biggest fear is leakage in an accident.
The major cons of relocating the tank is displacement of spare tire and cost. I will probably relocate for the space. I carry alot of photography gear with me that I have nowhere to store. I am not comfortable in throwing a $5000 camera setup in the bed.
![]() 66 Chevy C10 LWB ![]() |
283 Drama Queen
![]() Join Date: Dec 2004
Classic Industries - Huntington Beach, has a nice replacement set. Had to replace my complete (because the idiot that stole my rig used a pipe wrench to twist the cap off - instead of just drilling the lock off the cap) assembly: Cap, Hard Neck, Rubber Tube and Clamps (about $45.00).
I’d go with the bed tank, but I’d like to get my rig running sometime in 2009.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
I have personally owned and driven 15 or more 4-5-6 Chevy trucks with the factory fuel tank in the cab. As stated, the fume issue is usually associated with a poor quality rubber fuel filler neck or poor sealing of the hose clamps. I have replaced them before and experienced zero fume issues.
My thoughts on the issues if involved in an accident are that if you get T-boned hard enough on the driver side or passenger side to compromise the fuel tank, then you probably won't live to tell about it. The most vulnerable areas of a vehicle are the front, rear and saddle areas...the center of the truck inside the cab is engineered to absorb the most impact, in order to protect the driver/passengers as best as possible, so I don't see a cab mounted fuel tank being a safety concern. In the demolition derby world, it is mandatory to safely and securely, install the fuel cell inside the passenger compartment. Last edited by LILRED66; 04-10-2009 at 12:32 PM. |
#6 | |
Airport Bum
The safest place for the tank is behind the seat, but plenty are putting plastic tanks under the rear frame. Go Figure!
Listen to the old timers, there old timers for a reason. ![]() Howdy, from a bit north of you. (FM156)
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark Last edited by Rogue; 04-10-2009 at 06:52 PM. |
![]() Join Date: Nov 2006
hmmm good topic, I'm also indifferent on it.
The only reason I moved my tank to the rear was for seat and storage space... safety wasn't really a factor, but it crossed my mind. There could be certain situations where a saddle-back tank may be safer, but there are definitely certain scenarios where I wouldn't want fuel in the cab with me, say a rollover or something. But if this is true, wouldn't it still be there today in new vehicles? Newer vehicles also use polyethylene tanks too, but I imagine it's probably more of a cost factor rather than safety, so I don't know who to believe. Last edited by 19GMC63; 04-10-2009 at 11:28 PM. |
Good topic.
I'm undecided, but leaning toward rear mounted tank. Fuel tank in cab = less inside storage Fuel tank in back frame rails = better rear weight and traction. not that I plan to drive in snow once I am done. |
Resistance is Futile
SSW made me think of something....if the tank was in the cab and you pulled up to the pump like it was an ATM, you could probably pump gas without getting out in the cold??? Sweet!!! ....or in my case, out of the a/c.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#11 | |
chrome makes it go FASTER!
Still can't figure out how the gas tank affects your spare tire mounting??
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#13 | |
I'm leaving mine in the cab. Like you I weighed the option and it just doesn't seem worthwhile to me. I don't care about a bumping stereo, would rather hear the exhaust rumble. Two kick panel speakers are good enough for me. The first truck I ever owned was a 95 GMC Sonoma reg cab. I never used the space behind the seat in that thing. $400 dollars to move it to the bed?.....nah, I'm good. Replace the rubber filler neck and call it good.
Just my $.02
Project 61 build thread Some people spend an entire lifetime wondering if they've made a difference....The Marines don't have that problem. Sic vis pacem, para bellum. -- "If you want peace, prepare for war." |
#15 | ||
![]() Quote:
#16 |
My tank was already moved. I wouldnt go back, although if I had an original truck it could stay there if I had enough legroom. If you want fuel injection it mite be tough to use the original tank. .....
#17 |
i have noticed another time when fumes are an issue is when fueling up, if you have the windows down, anyway....
Jeff....that would be a funny site ![]() what ever happened to full-service? I haven't seen one of those stations in for-ever I know that several years ago you were not allowed to pump your own gas in Washington state, it was against the law ![]() sorry for the side-tracking thread-'jack ![]()
#18 |
#19 |
ok....ya got me
#20 |
Joe, we get quite a few of those Washington snowbirds and Ive heard of some younger people dont know how to pump gas (chicks anyway).
#21 |
In the state of Oregon, you are not allowed to pump your own fuel.
#22 | |
#23 |
I had fumes and it turned out to be more than that by the time I realized it. Fuel was leaking into the cab when I would set the pump and leave it to fill the tank. The down pressure of the handle would push up at the nozzle and eventually created a crack in the rubber filler hose. Definitely replace it every few years, especially in a dry climate like the desert SW.
I wouldn't give a second thought about moving the tank for safety reasons unless you're 4 wheeling and there's a chance you could put it on the roof.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#24 |
Oregon, that's right, dunno why I said Wash.
#25 |
Well I plan on putting my in cab tank in the bed and build a "box" for it. Kind of like a trunk in the front of the bed. I got my truck and the guy had put in a brand new tank in and I can't see spending @$300 to put it under my truck when I plan on slamming it to the ground. I think the trunk in the bed idea is the way I will go.
