![]() Join Date: Sep 2008
'68 on bags, "Shop Truck"
Finaly its been nice out and I've had time to start this project. As of right now I'm going to be keeping the stock v8 and 3speed w/overdrive. (Actualy ran the numbers on the block and found out that its not a stock 307, but an '80s 305).
As far a suspension, I have 4 D2600 w/ SD's front plates and cups. ECE's super track bar and shock relocator. Need to get drop spindles and disk brakes yet, and I have the steel to make 2'' blocks. I need to call SD up and order some valves/tank and such. I also had a guy give me a York 210. Took the bed off to start on the back. started by taking the shocks off and cuttin rivits for shock mounts and bump stops. After that I got the spring out and bags mounted/w tep. air lines so I can move it around. Keep in mine nothings painted, and I have to go over everything agian, but this is where im at now. Started with ![]() ![]() ![]() ![]() frame rails are on the axle tubes! Next nice day Im going to work on the track bar and shock relocators. |
Re: '68 on bags, "Shop Truck"
Well its been raining for about 2 days now so I havent had a nice day to work on work on my super track bar or the shock relocators. Since I had the stock to make blocks I thought I would use a friends mill and put holes in them! Started by cutting the stock to lenght (used the spacer from my ECE track bar as a templet). Located my holes and started drilling. Started with a 1/4'', then 1/2'', finaly an 7/8'' end mill. The U-bolts that come with the ECE track bar are longer than stock, but dont look long enough for much of a block, so I got new U-bolts from the spring shop that are extra long. Since everyone likes pics..........
![]() Setting up the mill after I cut the stock the length ![]() Using the 7/8'' end mill. ![]() Done! ![]() On a side note, I was at a swap meet last weekend and found a new viair 480 and only payed $100! Came with an viair gauge, little bit of 1/2'' and 1/4'' air line, the filter and extra foam for the filter! ![]() Also ordered the viair 3/8 starter kit from SD. So I can start to mount my tank and valves while the beds off. Last edited by nicks05z71; 04-15-2009 at 06:22 PM. |
Also I have some questions. I know I've seen a thread with this in it but I cant seem to find it.
Would it be a big deal to mount the 480 and 380 on the same tank? I want to wire it up so i can run one or both, so when my tank is really low I could have faster fill times, and when Im at presure I could shut one off. This would also act as a backup if anything should happen to one comp. Another question. Below the axle I have wedges. (correct the angle?) Is everyone putting these back in? I just dont like the fact that I would have to stack 10 things under the axle.....axle tube, track bar, block, wedge....you get the idea. |
Been awile since I've updated this. I've been working on the tank and valves, wiring and plumbing.
I took my tees and drilled and taped 1/8NPT for gauges. I've used locktite 545 on everything. all parker PTC DOT fittings. ![]() ![]() found some Monster brand 9 wire for the valves, should be here in soon and ill start workin on the wiring. Havent done anything to the front yet. Last edited by nicks05z71; 06-16-2009 at 01:35 AM. |
looks good!
dazed and confused
i like it. keep up the work.
members met: redbaron69, billsbowtie,nc67 |
More pics...
480 mounted - 380 on the other side ![]() Power steering on and working great. Best 50 buck I spent on the truck I think. Going to make it so much nicer to drive. ![]() Finaly a side shot. These are the wheels that where on it when I got the truck. sanded, cleaned, and painted white. some tires I had around the house, 255/60/15 if I remeber right. ![]() Started running the power wire for the viairs. 4gauge on the pass. side of the truck split into 10gauge. |
Keep it up! How much did you pay the spring shop to make your u-bolts?
Hella good start!!
looks really nice, wish i could find a clean truck like that up here to build a shop truck, but all of ours are rusted right out.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
Under Construction
nice progress.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Tot Roddin'
This is going to be a sick little shop truck, keep at it!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Been awile since I updated this. I've been working on the truck little bits at a time. To date I've mounted all 4 bags, wired, and plumbed. I havent been doing very good taking pictures sorry.. i do have a cellphone pic.
![]() My father signed me up for a goodguys show coming up and I didnt have the truck together.. so I have not put spindles and disks on yet. Stock spindles and uncut cups. It shows because the front is still high. Ive been talking to a paint guy about some pinstripes and maybe a logo, but dont know if that will get done by the show. |
#15 |
VA72C10
![]() Join Date: Mar 2008
Looking good...I really like the truck! you need to post up the new pictures with the shop logos!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#16 |
Thanks! You looking for these?
#17 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Dude, that turned out sweet!
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#18 |
Thats awsome! Im digging the old faded logo's!!
#19 |
Love the look thats what my truck is built to look like about to take rims off mine and put whites
#20 |
Still Learning
nice!! VERY Nice!!
#21 |
low n' slo
![]() Join Date: Mar 2009
nice work so far, i like the look your going for. i sent you a pm also
